Rikon 18" bandsaw fence opinions
Andy Wright - Allen, TX
>I have a JET 16" bandsaw, and it did not come with a fence. I have been using a an aftermarket fence that came off my old 14" bandsaw, but I am not satisfied with it
I found a guy selling a fence that was pulled off a 18" Rikon bandsaw for $50 on Craigslist, and was wondering if anyone had experiance (good or bad) with this fence.
Also, the fence is designed for a 19" deep table but my saw has a 17" deep table. The seller told me that it is a minor modification to make the fence fit a smaller table. Any opinions on that from someone who has the fence in front of them?
A picture that was posted with the craigslist add is below for reference
Re: Rikon 18" bandsaw fence opinions
>I have the 18" Rikon.
You would have to adjust the small plastic part on the back end of the fence by loosening the screw and moving the plastic part to where you have the back rail. Then tighten it down.
All you need is a Phillips head screwdriver.
I think the tough part is getting the rails on your saw table.
I've used the fence a lot. I initially thought it was a bit light - but it does work. I do wish it was a bit taller though.
JL - is it a decent fence?
Andy Wright
Thanks JL
I like it.
>As I said, I thought it would be a bit light. But it holds well. I've resawed with it using the small pivot bar provided.
Ideally, I'd like a 6" tall fence and bar for resaw work - particularly if you are resawing 10-12" boards. But I don't know what the resaw capacity is on the Jet. I've got a 12" capacity - therefore I'd be more comfortable with a taller fence.
