(Message Deleted by Poster)
Bob S
Re: (Message Deleted by Poster)
I doubt here is a reliable reduction formula
Bill Tindall
>If you want to remove the luck factor from design you need to either build a mock up. Or, if you can "picture" the table from a 2-D drawing then you can make scale drawings of a frnt and side view.
Making a drawing can be as easy as drawing it to scale on graph paper with a straight edge or on a drawing board if you have one.
I find that I can reliably picture something from a 2-D scale drawing if the piece is all right angles, but if it involves curved forms then I need to mock it up from cardboard, cheap wood, Masonite, etc.
Need Profile to post links
>Bob, to encourage registration and prevent spam bots from posting unwanted links, you must now register if you want to post links on these forums. There are other benefits to registration as well, so I hope you will consider it. We'd like to see the plans you suggest we look at.
Sorry for the detour,
Ellis Walentine, Host
Re: Tavern Tabel - How to Scale Smaller
John McGaw
>I don't use plans as such but there are certainly things is would consider. First off, scaling the height would be entirely self-defeating unless you also intend to have scaled-down chairs and intend the table for a child's play tea party. 30" or something very close to it is a given for a dining table. The top could easily be scaled proportionally. The aprons and legs could also be scaled down but I might not go as far down as proportional but that gets into matters of strength and usability. Aprons could be made thicker to regain any lost strength but that isn't possible with legs. But if the original design has really beefy legs you probably could just scale them proportionally and thicken the aprons. Just my $0.02...
Sorry no image
Bob S
>I couldn't quickly figure out how to attach the image. Here is URL if you care to look http://www.tablelegs.com/WoodworkingPlansAndArticles/ColonialAmericanTavernTable.aspx
Re: Need Profile to post links
Bob S
>Ellis, I had been registered before. Unfortunately I can't figure out how to login anymore. Can you please check to see if i am registered, or let me know how to do it. I enjoy this site immensely and am back into woodworking after a 4 year boating/fishing diversion!
Dan Donaldson
>Bob, due to interaction issues with the new board versions, most all of the old profiles were deleted. Just go to the profile section and create a new one for yourself using whatever name you plan to use here. After that, you will see all of the enhancements Ellis has added and be able to post links and pictures.
Tavern Table - Scaling (oops)
Bob S
>Well I mistakenly deleted my original post, while trying to add a picture of the table I want to make. :(
Original Post: I want to scale the top of this table from 36 x 74, to about 26 x 54 or so. I have questioned if it is important to scale all other pieces (excluding height! We are small but not midgets!). The table will be used for puzzles or whatever, and size needs to be 26 x 54.
Thanks for any additional help.
Here is the table:
Jim DeLaney, Austintown, Ohio
Re: Tavern Table - Scaling (oops)
>About the only change I'd make would be to reduce the size of the side and end aprons a bit - maybe from 4" to 3�" or 3�".
On the top, I would modify the breadboard attachment a bit, and only use three dowels - one at each end, and one in the middle. Elongate the holes for the middle and back dowels, but not the front one, so that the front edge is always even, and the back 'floats' with expansion/contraction.
Jim D.
