why it is called "green"
Bill Tindall
>Typical lacquer thinner is a mix of acetone, some less volatile solvent that is either a ketone or an ester and an aromatic hydrocarbon, usually toluene. These ingredients are either not natural products or products of natural products, and/or they are considered VOC's. Very non-green. But they have survived the test of time in terms of safety and effectiveness. Toluene and acetone are considered the safest solvents to use on an industrial scale, and duh, that is why they are so widely used.
This "green stuff" eliminates the aromatic hydrocarbon and replaces it with "natural products" that are most likely made from petroleum and not from natural sources. Acetone is not considered a VOC.
If I remember correctly one of the main components of the "green stuff" is in fact considered a significant breathing hazard and it has been removed from many formulations for this reason. Unlike regular lacquer thinner spilling this stuff on your hide with its large concentration of low volatile acetic acid will likely result in a chemical burn if not washed away quickly. Bottom line, I consider the regular stuff safer to use.
This material seems to be yet another example of the public being mislead by those capitalizing on "greenness".
