battery start added to generator
Carol Reed
>In the winter I store my motorcycle and have to keep the battery charged. I just got a propane generator for the winter power outages. My back isn't always up to yanking on that rope to start the thing. See where I am going with this? :D
Is there a battery starter kit for rope starter engines that can be added on?
Re: battery start added to generator
Howard Norman
>Depends on the generator Carol. My Honda EM5000 had a factory available accessory kit for electric start. Check the web site for the generator manufacturer and see if one is listed for your generator.
I am not aware of a generic one and doubt if one exists but I have been wrong before.
h
Here's a hack:
Grant in Iowa
>I am not sure if there is, but if you post the model # of the engine we'll help you look it up online to see if one is available.
But here's what I did to an old toro lawnmower. it was a 4.5HP vertical shaft walk behind amchine with electric start. I used to pull start it, but one day the recoil rope broke, and I needed to mow. So I took off the assembly to inspect it, and noticed the large nut on the end of the flywheel. So I found a socket that would fit the nut, and installed an adapter in the drill to accept the socket. With the drill in low gear, I was able to start it no problem for years. I just had to be careful to remove the drill and socket at the moment the engine took off. It was a 12V DeWalt cordless drill.
Might work for you. Make sure you are rotating then engine the correct way if you try this!
I think a benefit for a generator is not having to maintain another battery that doesn't get used much.
Again, if you post the engine model #, we should be able to determine what is available for that engine. Most engines 8HP and larger will have such an option available for around $120 or so plus battery.
Regards,
Grant in iowa
Re: Here's a hack:
Don Evans
>That just doesn't sound very safe to me! Possible broken wrist or arm in the future. Don
another option?
>Carol,
Are you sure the generator doesn't already have a starter motor? When I bought my Honda generator years ago the salesman offered to sell me an electric starter kit. I declined.
Later, looking closely at the generator I discovered everything needed for the electric start was there except for the battery bracket and cables. I added my own cables, fastened a board to the top for a secure place to set an automobile battery, and cranked away.
Also, do you know about battery tenders? Lots of people use these to keep vehicle batteries (in construction equipment, motorcycles) in good condition over the winter. They automatically charge as needed then trickle as needed to keep the battery in top condition, regardless of the temperature. I have two and rotate them between 4-wheelers, the big mowers, and the bobcat - everything that I don't run periodically. I bought my battery tenders at a local Batteries Plus store; seems like they were less than $50 each.
