Router Inlays
Stephen Kirk
>Well, I picked up an inlay kit for the router. After adding a new baseplate to take the guide bushing I was off. Tried a simple circle with great results. Then I made myself a butterfly template and that also worked well. I was just trying it out and used some thin hardboard as the veneer and added it into some old plywood.
Only odd thing is that the inlay piece was too tight and needed quite a bit of sanding. Not sure what caused that. I did center the bit first.
All in all, this is a nice and simple technique.
