We value your privacy.
>I'm making a rather large shadow box ) 33'' by 39''. I going to be a Hockey Jersey display case. The back of the box is going to be covered with a blue velvet. Never have done the velvet thing before I looking for advice, tip, or instruction on how to glue this velvet to a 1/4'' piece of plywood.
>Pretty easy with 3M "77" spray adhesive. Two coats and allow to dry until just tacky. Then apply the cloth, gently stretch, then smooth from center to the edges.
>I use felt but same-same . . . cut the cloth so there is WAY plenty (you only get one shot at this), yellow carpenter's glue, sqee-gee it around (I use a finger) so its fairly thin, lay the cloth down then "iron" it out (from center to edges) with the heel of the hand. NO ROLLERS ! Be carefull not to push to hard as not to saturate the cloth and have the glue come to the surface. If you are dead-set on some kind of "cement", try a test first. Some fabrics react badly, depending on the blend, and might melt. Been there, done that. Icky, gooey mess.
>Zip on down to the local fabric store or crafty store and pick up some Aileen's Tacky glue. The stuff costs $2.50 for 4oz. Plenty for what you'll need. Sewing people use it to hold a pattern and fabrics while sewing. Get the original white---white--drys clear and flexible. It is relatively low tack -- but more than strong enough for the backing.. It is thick, very thick. Wear gloves as it is tenacious stuff. Practice before use just to get the feel. Use a tongue depressor or the like to spread and toss applicators when finished. Relatively short time to apply so have everything ready. Do a test run so that you have smoothers, scissors and anything else you need until you have done this a couple of times. I've never had a bleed through--especially on thick cloth, but apply thinly anyway. APPLY THE GLUE TO THE BACKING BOARD not the fabric. When applying it works like contact cement. Usually just the edges will do (start at the top) and some spot dabs where you feel necessary. It is not very repositionable but far less mess than 3M77. The secret however is to drape the velvet for a couple of days the eliminate as many wrinkles (unless you use crinkled velvet) as possible. Steam it smooth if you need to. Let it dry completely hanging with no folds. When its time to attach I try to take the back of the mounting board to the cloth as it helps avoid wrinkles which seem to happen instantly. I anchor the cloth down as I would positioning laminate, a section at a time, and smooth as you go. The back must be dead smooth with no voids. I use 1/8" art board acid free not wood as the sweater contact .. Easier to use and stains will not eventually get to the fabric of the $100 hockey sweater as it will with wood unless sealed. You can then add the art board over the plywood as a layer. Note: the velvet (are you using real silk velvet or the cotton or nylon stuff?) will pick up the glue so be sure you put the fabric right side up. With the frame I also drill some very small holes on the top and bottom so that there is the opportunity for air inside the frame. It helps the fabric. A hockey sweater is heavy, how are you mounting that? Aileens can be used for that too but over time the glue will crust up --most will wash out though. I've seen stainless staples used. Don't count on the front glass to hold the sweater. Hope this helps.
