Veritas - Innovation in Tools
shop heat part 2
shop heat part 2
shop heat part 2
Carol Reed
>The plumber was here and extended a propane valve into my carport. I have metered propane to the property. Metered propane is 1/2 as expensive as propane in the cylinder tanks.
The plumber verified that gas was flowing through the new valve. But a problem came up - and not his problem!
I have tarped in the carport to slow the wind and was using a two head Mr. Heater to bring the temperature to survival levels. When Mr. Heater was perched on a ten gallon tank, he worked just fine. Now he won't light. If I hold the valve in long enough, he will eventually puff out the butane trigger lighter I am using to light him.
The new gas valve is connected via a 5' hose (swiped out of my B-B-Que until I can get another.) into the valve body of the Mr. Heater where the tank connection was. That valve body is an on/off, lo-med-hi valve. Is it also a regulator? Mr. Google was no help here.
Any HVAC guys here, with some propane experience. Anyone know what the problem is and what to do to fix it?
Re: shop heat part 2
Lee Schierer McKean, PA
>Most likely there is air in the line and it needs to be purged before your heater will light. To purge, turn off the gas and loosen the fitting closest to the burner that you can reach. Crack open the gas shut off and let it run until you can smell the gas. Shut off the gas valve and tighten the fitting you loosened. Wait a few minutes for the gas smell to go away and try relighting.
The other possibility is that the line pressure of your propane line is different than what is needed for your heater to run with. You may need a regulator or a new regulator in the system.
Lee
Carol Reed
>We did the purging thing, Lee. As for the system regulator, if you mean for the metered propane, that regulator is built into the main gas meter. Sincerely doubt the gas company would change that.
Would that also not mean the valve body on the heater includes a regulator and that with this in-line, I am regulating already regulated propane?
And if that is the case, what am I risking, aside from the obvious big boom, if I remove that valve body and run straight into the Mr. Heater?
Gary Camp, Bend Oregon
>Carol your Mr. Heater is designed to run off propane bottle pressure (about 18 psi) and should have an internal regulater. Depending on where your plumber tapped in to the propane line you are probably at 5 psi or less, and could be as low as 11" w.c. (about 1/2 psi). It sounds like your Mr. Heater is being over regulated. Not knowing where or how your system is plumbed this is my best guess. Here at the rockpile we pipe propane from a central location at 18psi then drop it down to 5 or less at each building then down to 11" at each appliance, I had a similar experience with a BBQ that had it's owns regulator. Your propane supplier should be able to help you (if the want to sell more gas)
Good luck
glc
>Carol, I think Gary has the answer. Not my area of expertise, but my first guess was that your piped in system was natural gas which runs at 5 psi or less and not propane. I would double check to make sure which gas you are using and what the pressure is. The regulators and the orifice for natural gas a propane are different. Many devices can be converted from one to the other. If Gary is correct, you have too many regulators in the system.
Carol Reed
>It's propane, Barry.
But Gary has the clue to the solution. I'll call the gas company tomorrow. I also just got a propane generator. The power has been off here for multiple days this winter and it ain't over yet. I want to be able to hook up this generator to this same valve when the need arises.
Thanks, guys. Most especially my good buddy Gary. And Gary, that meal we had on the mountain 5 1/2 years ago was still the best meal I have ever eaten!
Howard Norman
>Carol, speaking from experience, if you haven't already I would suggest that you hook up the propane generator and test the various things that you want to operate from it before the next storm hits. I found problems operating a furnace here from a gasoline generator as did a friend of mine near you in Payson. We finally figurered out a solution but not until the parties involved had suffered through some heat less days during one of our power outages this winter. Surprising my furnace did not have any problems but the neighbor across the road was the one here having problems.
howard
Carol Reed
>Thanks for the heads up, Norman. Can you tell me what sort of problems? I expect to have the gas man out here tomorrow or early next week. I will have the furnace set up to be plugged into the generator so we can test it.
Howard Norman
>Carol, the problem was a short cycling problem in both cases. Short cycling occurs when the furnace fires up for a few minutes and then shuts off for a few minutes then fires up again.
When one has a power outage in the winter time the one thing that you want to be sure that will run is your furnace from the generator!
