miter saw recommendations?
>I use a older Makita miter saw (non-sliding, non-compound) and am considering a new saw. I see these sliding compound miter saws with lasers and all the works. Are they good for precision work or is it better to stick to one with fewer movable parts? Seems like alignment might be an issue after extended use.
I looked at ads for a few. The Festool looks nice but is pretty expensive. (I have a Festool router and it seems well made).
Any recommendations based on experience?
Re: miter saw recommendations?
paul in AZ------WebKitFormBoundary+isMX5X2paiDYC5e
>I have a Makita LS 1013 and absolutely love it. About 6 years old now with plenty of mileage. I probably use it more than any other power tool I have. Still dead accurate with no slop at all. Powerful enough to melt through really hard woods like wenge and jatoba. I can't tell you how it compares to others around because once I bought this saw I have never given a thought to looking at the competition.
For my money the lasers and such gimmicks are cute marketing tools and little more.
Miles Lunde
>John,
Thanks for the concern and tips on finishes awhile back. About the miter saw, I have the 12" Dewalt slider, it has never failed to perform with the right blade, and that is the key, the blade! But having it, and the portable stand, everyone thinks it needs to go to their house for the weekend shed, or deck. I'm thinking of turning it to a constuction only saw.
With that, when I buy a replacement it will be the 10" Bosch slider with lazer, if the lazer is set right, how could one go wrong. You need the slider for the occasional 8" to 10" board.
If you need model numbers I can get them for you. When I looked into saws, I thought this was the best on the market.
Happy shopping,
Miles
I second the motion
Clint Searl, at the base of Haycock Mountain
>The Makita is a real workhorse and very portable. I also have the Hitachi 12" slider with micro adjustment and laser. The micro adjustment allows for very fine tuning, but the laser is only good for eyeball cuts. The saw has great depth of cut and will handle anything that can be fitted under it, but it ain't too portable unless you're a knuckle dragger. I keep mine bolted down on a dedicated station.
Clint
Re: miter saw recommendations? *LINK*
mdclor
>John,
Just to through another name into the mix, I have had a Hitachi C10FSH for the past 8-9 years. It was dead accurate out of the box and has been ever since. I mostly use it as a cut off, but have done compound miters and been happy with the results. The supplied blade leaves a glass smooth finish.
FWIW,
Merle
C10FSH
I have the LS1013 and (sorry) hate it
Terry Alexander
>I have had the LS1013 for about 8 years. It was not accurate on delivery, the instructions for truing up the accuracy are almost worthless and the tilt to 45 or other degrees is not consistent.
I use mine to rough cut 2x4's. That's about it.
I have a friend who purchased a Hitachi. He is a custom guitar maker and his tolerances are in the thousandths (as you can imagine). Since purchasing the Hitachi, he says he turns to his miter saw whenever he gets a chance because it is always dead on....and.....in his work, he checks accuracy before every single cut.
My $.02 worth.
Terry Alexander in West Texas
Stuart Johnson
>I have an older DeWalt so can't give direct feedback. Malcolm Tibbetts (segmented turning) has gone to the Festool. He says with the slow start and precision he has been able to stop sanding many of his segments. You might want to send him an email at malcolm@tahoeturner.com and get his opinion.
Andy Wright - Allen, TX
>I have the "newer" Dewalt 10", and have been happy with the accuracy. I bought the light instead of the laser and really like it (it shines a white light from behind the blade which not only improves your lighting, but also leaves a shadow where the blade is going to leave its kerf.
My main complaint is dust collection - the Dewalt performs poorly in that department
Another vote for the Makita
doug f, san clemente, ca
>I've had mine for about 10 years. It's done decks, flooring, construction and very fine cuts for small, mitered boxes. Still the most accurate crosscut device I have. If I do have the occasional 8-10" board to cut, I use the table saw (Laguna with a sliding table).
I upgraded the Makita blade to a Forrest Chopmaster several years ago and it's still deadly accurate.
Doug
>Good Morning John,
My #3 son is a contractor who specializes in trim work on high end jobs. He just bought the Mulwaukee 12": slider. Its extremely accurate. Ken usually works within fractions of a degree. The laser is also very good, but his own eyes are better.
FWIW, he's used his 12" DeWalt slider for years at site work and its still going strong. Unfortunately his "helper" dropped it, compromising its accuracy somewhat. Its still in use, but only Kenny can make the necessary compensations consistently. So, DeWalt and Muilwaukee. I have a Hitachi without laser, and in muy small shop, it works fine.
George
FredD
>I have had a 14" Makita Mitre or chopsaw since they came on the market back in the early eighties and I wouldn't trade it for any other "new and improved" version .
I mount a Oak sacrifical fence to it and this allows tacking a height stop for cutting absolutely dead on Cove and Crown moulding.
The only thing that lacks in design is the plastic blade guard that rapidly became impossible to see through , so that is wired up out of the way.
FredD
