Two videos on changing bearings
>Here are two recent videos by Jim Tipton, of Hampton, NH, who took issue with our old Badger Pond article on changing contractor's saw bearings. He's created these videos to set the record straight. See what you think. Personally, I'm wondering what technique would work if you don't have an arbor press and all the custom tools that Jim uses. Anybody have a workaround?
Re: Two videos on changing bearings
>Pretty Neat. I have a Delta/Rockwell contractors that is over thirty years old and have never changed the bearings. Did not appear all that daunting. I would give it a try if the bearings go bad.
I don't have the specialized tools or the arbor press. I would have to remove the retaining ring with a screwdriver as he mentioned. Probably would try to make the press extensions out of PVC pipe. And I would try using my Drill Press (with the motor OFF) to press things in and out.
A couple of small Criticisms. I wish he had given specific information on the bearings. Sealed, Shielded, What?. And He could have shown a close up of the tools. I take it he made them. Is he in the business of replacing saw bearings? Why would he have these specialized tools? Or are they so easy to make that anyone could make them for a one time use?
And as a tiny complaint, Next time wear solid black gloves. I found the white writing to be distracting. I know that's small, but what can I say, they bothered me.
Gary Camp, Bend, Oregon
>Good morning / afternoon
The work-around I use in place of an arbor press is an 8 or 12" C-clamp and a piece of pipe or emt the right diameter. For the puller he used on the shaft, a NAPA bearing puller for around 30 bucks would work, or a piece of square tubing, a recipsaw, drill, tap and die set and about an hour. You might also try the short ends of two flat bars, clamp the shaft lightly in a vise hook the ends of the bar under the bearing and pull out (there may not be enough shoulder on the shaft for this to work). The retaining nut wrench could be made with the right diameter pipe and a Dremel type tool in a short time, no need to use it with a rachet, drill a hole through the other end for a screw driver / twister. As stated you could just try it with a screwdriver
del schisler
>i guess if their is a will their is a way I made due with lot's of work around tools I have pull and put on beiring's before Sometime's it isn't that much fun But cheeper if you have the time and make a few item's to work for you If it is a one time make due my 2cents
I didn't need special tools`
Bill Tindall
>I don't know about this particular saw but I posted directions for how I changed bearings on a Unisaw and nothing but a wrenches were used.
Jesper, Denmark
Jesper, Denmark
>Ellis, there is no need for special tools. The arbor press can be replaced with your regular vice and various bit of pipe around the shop can be used as spacers.
He does not mention cleanliness and removing any burrs from the shaft or bores - which will help making the assembly much easier. A little oil also goes a long way.
I would also second the recommendation of using sealed bearings - they do not cost much more than the regular ones.
