Delta 33-990 Radial Arm Saw
Craig
>Just purchased a used Delta 33-990 10" radial arm saw for the shop; excellent condition. Does anyone have info/suggestions for the following:
a) Drill chuck for the arbor for setup to perform horizontal drilling
b) Does the saw motor/blade housing have the capacity to cut dados or rebates 3/4" +/-width
c) Feedback on which blade performs "best?" Currently I have a Freud 10" Ultimate Crosscut with the following specs: 80 tooth / High ATB / 12 degree hook / full kerf. Is this to much hook? Crosscutting on VGDF last night very smooth cuts with no tear-out... but, i noticed the motor does "feel" like it would travel towards me if i did not have pressure against the handle.
Thank you in advance!
Craig
Re: Delta 33-990 Radial Arm Saw
FredD
>Craig,
The saw will cut Dado's easily, the horizontal drilling could be more excitement then you anticipate at the motor speed.
The blade you have while a fine blade for Table saws has a high potential for cutting off your fingers with that hook..
Get at least a Zero hook blade , negative hook is even better in a 60 tooth ATB configuration.
Check not only the square to fence set up , look for heeling , which will give you ragged cuts on one side of the cut and burn marks because the back of the blade isn't following the same track that front is.
Enjoy your saw, Delta made a good one.
FredD
>I agree with Fred. I have had a RAS for over 40 years. It was my first stationary power tool.
The advice on the blade was good. You will be pleased with a negative rake blade. I have spent a lifetime doing that pull push stroke for the RAS. You pull a little to get it started and then push to hold it back. The right blade helps a lot.
Rod Peterson�Ormond Beach
I don't have a Delta RAS, but I've had a Craftsman RAS for many years, although it hasn't been used much for half of that.
a) I generally found the accessory shaft to not be very useful. Horizontal drilling is quite limited unless you build a sled. Routing is rough because the arbor speed is way too low.
b) Again, Craftsman, not Delta. Mine would. See notes below about control.
c) Nowadays, 12 degrees is considered very aggressive for RASes. Most users with less than fifteen years experience with a RAS will recommend something with a negative rake. However, back in the day (from when RASes first saw a lot of use--late '40s, early '50s) there wasn't much blade selection, especially in the negative rake, so people used the same blade in their RAS as they did in their table saw. See notes below about control.
There is definitely some technique involved in using a RAS. As you pull the carriage back for a cut, the rotation of the blade would tend to pull it into the wood if you didn't control the travel with your arm . It quickly becomes a natural and instinctive motion and is not something to be concerned about. Naturally, with an aggressive hook there will be more tendency for the climb than with something with less rake, but, as I said, back in the day it was never a problem.
Dado sets just require even more control (although it's not massive--awareness is as much of a key as anything), as they can take a big bite. You may want to consider using a 6" set instead of an 8" set just for that reason.
Do not believe the "horror stories" on the internet about ripping with a RAS. Almost all of them are legendary and based on an improper application of technique contrary to common sense and manufacturer's instructions. The improper application came about because someone was afraid of their tool. There is a much better and much safer way of dealing with a tool of which one is afraid--don't use it.
Respect, however is an entirely different story. With respect, care, and practice, safe RAS operations are quite easy. My principal beef with mine (and a common affliction with Craftsmans) is the ease with which it could be knocked out of alignment. The Delta may be better at that.
Do yourself a favor and buy the book "How to Master the Radial Arm Saw" by "Mr. Sawdust" Wallace Kunkel http://mrsawdust.com/
It focuses on the DeWalt from years ago, but most of the principles he discusses are applicable to almost any RAS.
Rod
Craig
>Fred and Barry,
Thank you for the feedback. It is greatly appreciated!
I noticed the motor has a smaller arbor shaft on the opposite side of the motor; ie. approx 1/2" in length. Is this where a drill chuck would screw on if i wanted to explore that option (after confirming the arbor speed!)? And do know if the arbor speed is the same on both arbors? I say this from my experience overhauling my chop saw that has gears inside to change the motor shaft speed.
I found several blades that look promising:
a) Freud LU91R010, Thin kerf sliding, 60 ATB / -5 degree hook
b) Freud LU79R010, Thin kerf Ultimate Plywood, 80 High ATB / 2 degree hook
c) Forrest, Woodworker I, 60 ATB / +5 degree hook
d) Forrest, Chopmaster 80 or 60 ATBR / -5 degree hook
If i just had a degree in blade engineering... do you think i will get a smooth finish with a 60 tooth blade on VGDF and mahogany?
Craig
Craig
>Thanks Rod!
I will get the book and start reading. I am a big believer in education and educated practice.
Thank you also for the feedback on the pressure control. I plan to install a vertical holddown clamp system at the fence for ensuring my cutting pieces stay put, and, keep my other hand out of the way.
Craig
FredD
>Craig ,
you can take it from a Professional Woodworker and Carpenter of many years experience, including "back in the day"
I ran cutoff saws (trade name for RAS) from the 1950's as large as 20 inch and believe me , if their had been zero or negative hook blades available , the trade would have used them.
For somebody with no experience in cutting thousands of 4-by and 6-by header stock to length, to make the assertions rod did, is doing you and anybody else inexperienced with that machine a great disservice, simply owning a RAS does not in itself qualify one to advise on their use.
As for ripping , it can do it in a highly inefficient , potentially dangerous method that leaves you no room for errors.
I would advise ripping on the Table saw, or the band saw , never on the RAS.
FredD
Rod Peterson�Ormond Beach, FL
>While "out of the way" is good advice in the abstract for digit preservation, your "idle" hand serves a very important function with a RAS. Not only does the machine provide a place to put it, but by using it against the work piece, you accomplish the following:
  • provides some down force
  • ensures registration of work piece for cut location
  • works in concert with pulling hand to ensure your own balance and to render feedback to the pulling hand for the resistance needed when in the cut
I have a hold down/against attachment, but it's only ever served useful when ripping. You'll find that most of the force against the fence needed will come from the saw blade rotation.
Rod
Craig
>Thank you Fred. Just crosscutting and dadoing for me with the RAS. I have a large tablesaw for any panel work or ripping. I do also use the tablesaw for tenoning and dadoing also, but on pieces less than 4' in length.
Craig
I highly recommend the Freud LU91R010
Tim Greif - West of Chicago
>Unlike many others, I still actively use my Craftsman RAS that I bought new in 1978. In fact, I would never think of getting rid of it. I use it as often as My Delta table saw. You'll find as many folks that hate em as love em. But the one constant is that it's a tool to be respected and careful with. Novice users are easily intimidated by the tendency of the blade to "jump into" the workpiece. You just need to learn the technique. And be especially mindfull when you use it with a dado blade the first time. After you try it, you'll know what I'm talking about. If you think a single blade can "jump", wait 'till you try the dado.
After many years of using it with various rip and crosscut blades, I finally wised up and got the Freud negative hook blade. I can't believe I waited so long. The saw literally feels like a different machine. Not only is the cut glass smooth, but the "climb tendency" is reduced significantly.
Get the Freud. Good luck with the saw.
Couple things
>I got my first radial saw in 1963. It was year #3 for Sears new design and it was a good saw. Not as good as an old DeWalt, which had a much more positive arm registration mechanism, but probably similar to your Delta, which has that center pivot joint as an additional point of articulation.
The trouble with radial saws is that most of them are pretty fussy to keep properly tuned and aligned. There are something like seven points of articulation between the work and the blade, so if anything gets bumped or torqued, your accuracy can go right out the window.
Back in the 60s, when Sears and Montgomery Ward were competing to put a radial saw in every basement, they fell all over themselves with snazzy features -- geared arbor (on the MW), planer heads, drilling and routing mandrels, etc. I have used every one of those features and think they are just about worthless.
Most pros you talk to only use the radial saw to cut boards to rough length, the first step in breaking down stock. Since they always are cutting over-length, the quality of the cut isn't a big deal. I recommend that for accurate, final crosscuts, you use a sled on your table saw or an accurate chop saw.
I have also ripped beaucoup thousands of linear feet of flooring and other stuff on the radial saw (When I started out in the custom/renovation business, the radial saw was my only machine, which I took with me to the jobsites in the back of my old Ford pickup.)
I never had any injuries from ripping, but I always knew what I was doing and was very aware of all the safety measures -- blade guards, anti-kickback pawls, proper push sticks. You really need to be careful ripping on a RAS.
Likewise with dados. If you have the slightest lapse of attention, a dado blade can rocket forward and embed itself in a workpiece quicker than a deer jumping in front of your car, and if you've ever hit a deer, you know how fast that is. I've had quite a few harrowing experiences with dado blades and radial arm saws. The worst part (assuming you don't hurt yourself or ruin a priceless workpiece) is that such violent episodes can throw even the heaviest-duty saw out of alignment. I recommend doint your dado work on the tablesaw or with a router.
So, there's my two cents. To me the radial saw is a cutoff machine, period.
Ellis Walentine, Host
Ellis - Your final crosscut comment puzzles me
>You say that the RAS is just a rough crosscut device and all final crosscuts are better done with a sled on the TS or with a CMS. Why do you say that?
I was taught by an old master to quickly verify a 90-degree cut alignment with a rafter square on the RAS every session I used it. Just put one leg of the square against the fence and pull the carraige full travel to verify that the blade just touches the other square leg all the way out. I find crosscutting on the RAS much more effective than using a CMS, especially for longer or wider pieces. The only time I would consider the sled is for pieces wider than 15" which is the limit of the cut on the RAS
Scratchin' my head here - west of Chicago.
Accuracy
>Hi Tim,
I'm not saying you can't make accurate cuts with a radial arm saw, just that these saws are prone to going out of square (both to the fence and to the table) and out of heel. These adjustments can go out of whack in the course of one or two cuts, so just truing it in one dimension at the beginning of a session isn't a guarantee. And there are so many points of articulation between the blade and the work that you can actually deflect the arm of the saw while pulling it, which can lead to further inaccuracies and tooth marks on the endgrain.
Let's just say that I myself and most of the professional woodworkers I've known reserve the RAS for rough crosscut work. Like I said, when I didn't have any other machines, I used the RAS for everything, so I know it can be done; I just don't choose to be bothered with worrying about accuracy all the time.
Hope that explains my comment a little better. Ever since my shop burned down, I've had a radial saw that somebody gave me (or did I buy it somewhere?) and I've never set it up. I use a 12" SCMS for most crosscutting, and, for wider stuff, I use a skilsaw. Final cuts are made with the SCMS or the tablesaw with a Dubby sled.
Re: Accuracy
FredD
>Tim,
What Ellis is saying about most professional woodworkers who crosscut with it only , myself included , holds true .
I only use a RAS for crosscutting , but I also keep it tuned so that using it for fast repetitive same length cuts is a cinch and for longer lengths a must .
Little stuff goes on the tablesaw for crosscutting.
In reality a 10 inch RAS is a light duty machine despite what you may think of 10 inch saws in general.
The frustration of dealing with resetting to specs after you have jammed a cut and twisted the head-frame momentarily is greatly abated after you install a zero negative hook blade.
Practicing cuts until you instinctively know which woods to start slow and finish slow in will also improve your performance and that is only attained by actually using the saw frequently which you apparently do.
I like you also use a framing square to check for right angle accuracy in the cut , but like Ellis says, don't forget checking for vertical ninety to the table and inspect the cut for heeling.
I have a Dewalt saw and in all but one respect is easy to adjust and that one thing is the adjustment for heeling which is pure trial and error.
I don't know what you will learn from a book , but the most important thing is to keep you left hand well away from the cut line while holding the material in place if your right handed.
The saw will never tell you advance when it decides to jam , so be prepared.
FredD
Re: Accuracy
Thomd
>I have a Delta RAS I inherited from some uncles. It never cut square, and I never tuned it. I just put a single piece of tape on the fence, and have been making seemingly accurate crosscuts since. It certainly isn't like using a milling machine. If I have a line on a piece I sometimes steer it along the line. So it isn't massively stiff. I wonder what the INCA RAS was like, though it looks awful.
I never do anything other than crosscuts with a RAS. Getting experience with tools can be a costly process. Ripping on a TS will probably eventually get your attention, and I don't think I want to be around when the same kind of lesson is dealt out with a RAS. Sooner or later some sneaky combination of unforeseeable factors will whip one into shape.
Erpelding's RAS joinery tape is interesting, though I never attempted the same with my saw.
Radial are sel fpropelling to some extent. So wood densities can be one source of excitement.
