Card Suit Inlays
Card Suit Inlays
Card Suit Inlays
Stephen Kirk
>I'm thinking about adding some card suit inlays to the poker table cover I'm making. A quick search didn't turn up anything I could purchase. Has anyone ever done or purchased and inlay like this? I've never tried inlay work but think it'd be a great skill to add.
The table top is plywood with a wide oak edging (bout 3") mitered around 2 halves of an ocatagon. Since some of the miters weren't perfect, adding an inlay over each one could help out.
So, easier to find a supplier, or should I buckle down and figure out how to make them myself.
Re: Card Suit Inlays
Dan Donaldson
>I would just look up some clipart for the suit images, size them as desired and print them out on your printer.
>Dan is correct. You can size them on the computer and then glue them to the veneer so you use your scroll saw to cut them out. I did it before I could use a computer. I sized them using a copier and then ironed the images onto the wood. Then just used standard inlay techniques with the scroll saw to cut them out and insert them in the veneer.
FredD
>one more thing to add to Dan and John.
Rather then looking around for card clip art , why not scan the cards
You could even cut the cards in to a pattern that suits you and then scan and glue onto your table for a cutting pattern.
Just a thought,
FredD
del schisler
>a google search may not be what you want
http://www.woodpeck.com/pokertemplate.html
Stephen Kirk
>That looks perfect and Woodcraft sells them too. Thanks!
