pedistal table base
pedistal table base
pedistal table base
frank ashmore
>Is a 24" base big enough for a 48" top?
Wil that be big enough to keep the table from tipping to easy?
Thanks for any help
Frank
ps use to be on this site all the time about 10yrs ago as mantelguy
Re: pedistal table base
Dave Bair, Eaton Rapids, MI
>For a 48" top, I would go with a 36" pedestal. Only if the top is extremely heavy would I consider a 24" base. No actual testing on my part, though.
FredD
>long time no see Mantel , you were a regular.
FredD
frank ashmore
>I decided to go with a 30" round base,it will be 6" thick and tapering from 30"to
15" where the base will jion the pedistal.Then Im going to weight the base to and a little more mass and stability
Another option
>Instead of making a great big pedestal, how about a much smaller one that is joined solidly to a beam structure at the top to attach and support the top, and four runners/feet at the bottom to resist tipping. There probably is some science to figuring out how wide the footprint needs to be to keep the table from tipping over, but you can probably guesstimate it. Don't forget to allow a safety factor, in case Aunt Tillie is in her cups some night and crashes into your table. ;)
Re: Another option
>I agree with Ellis. (I always agree with Ellis, He's the Boss around here)
An Engineer would tell you there are a couple of ways to make something less tippy. You want to lower the center of gravity. Either spread the base or arrange for the weight to be lower. The other problem you have is the one Ellis Mentioned with Aunt Tilly. If the Feet were the same diameter as the top it would be nearly impossible to tip the table by pressing straight down on the top. But you can't count on people to press straight down. They might crash into the table at an angle.
I have a pedestal table I made years ago. A heavy set of "feet" and four vertical posts that are about 4x4's. A top slightly larger in diameter than the feet. The rails for the top have slots in them to allow the top to expand and contract and float. It is very stable. I would send you a picture, but it is disassembled and in storage.
