Wall Cabinet
Don M
>I am planning to make a very basic wall cabinet for my shop. It will be 7 1/2' X 30". It will be made of 3/4 birch plywood. All joinery will be with #20 biscuits. The cabinet will have one horizontal shelf running its entire length which will divide the cabinet into an upper and lower section. Each section in turn will have to vertical divider panels that will result in a total of 6 large cubby holes, 3 on top and 3 on the bottom.The back will be a piece of plywood that will be rabbited in so that it is flush with the sides.It will be glued and nailed to the sides and top and bottom and finishing nails will be driven along the horizontal shelf as well. The cabinet will be hung on 2 cleats, each about 5' long one at the top and the other near the bottom. The cabinet will carry a fare amount of weight probably near 200lbs.
I was planning on using 1/4" plywood for the back, is that enough or should I go to 1/2"?
My concern was the back being pulled off.
Thanks for the input.
Don M.
