Apprenticeship, week 16
Nathan
>Last Thursday, Master kept his promise and had me �stand at the lathe all day�. Fortunately for me, I didn�t just stand there - he turned it on and showed me some basic techniques, and I actually turned three candlesticks (beech and white maple) and a small spruce bowl. It was great, although I didn�t actually finish anything. Since I turned the candlesticks out of narrow material, I�m going to have to make bases for them separately. I started on a beech base, but it took forever just to rough it out. The pine bowl is finished from the outside, but I haven�t started on the inside yet. Still, I was surprised that I was able to actually make something remotely useful on my first time at the lathe.
Today Master was out all day, so I was sort of left to my own devices. This was the second time, and both times I tried to make the best of it by practicing at the grinder and sharpening station. Today I spent two or three hours at it. Here are some observations:
(1) It�s important to get a feeling for the stone you�re using � i.e., how fast it cuts and how flat it is. Today I managed to get that feeling, and I must say, it felt good but it was a long time coming. I spent over an hour trying to flatten the back of a 1� chisel, which I thought was improperly sharpened. I thought my stone was just cutting REALLY slow, but the longer it took to flatten the back, the more suspicious I got. Finally I decided to try 220-grit sandpaper � I figured that might speed up the process. I found a piece of float and imagine my surprise � with only a few strokes (3? 5?) the back miraculously became flat. At that moment it dawned on me that the stone was concave and that no matter how long I stood there, the back would never become flat using a concave stone.
(Ha, I know this is really basic stuff, but it marked a major leap in my understanding of and skill level in sharpening.)
So I decided to ask for help. Master wasn't in today, so I asked one of the guys. He suggested that I flatten the stone on the side of a big grinding wheel that was lying around. I tried hard to get the stone flat, and I did make some progress but it was very slow going (though not as slow as the process of flattening the back of the chisel on the non-flat stone - it was encouraging to see real progress). After about an hour I judged that to get both the "coarse" and "fine" sides of the stone truly flat, I'd have to rub it on the grinding wheel vigorously for at least another 2 hours. Still, I had made enough progress to see that the stone was now flat around the edges and on both ends. Flat enough to get a chisel sharpened properly.
(2) The question is, at what point do you declare it "sharp"? Someone � I think it was Christopher Schwarz � wrote that as you gain experience in sharpening, your definition of �sharp� changes. I�ve found this is true, even in my short four months of sharpening. When I started, I was delighted at the �before ... after� difference between my totally dull tools and what they were transformed into when I rubbed them in the right way on a concave stone. Soon, though, that no longer seemed sharp enough to me. When I got a bit better at sharpening, I was delighted when I managed to raise a burr across the entire edge of the tool and chase it on finer and finer stones until I couldn't feel it anymore. Now, though, I�m realizing that this level of �sharp� (at least in my hands on my stones) is what Christopher Schwarz refers to as �working dull�. Today, I would like my chisels to be �shaving sharp� when I�m finished with them on the stone, but either my finest stone (a piece of slate) is not fine enough, or my technique is not there yet.
(3) On the other hand, I�m not sure if attaining shaving sharp is worth the extra effort. It seems like after spending lots of time getting a tool to that level, having it revert to �working dull� after a couple minutes of use will be discouraging.
(4) I now understand why many woodworkers refuse to let anyone else sharpen on their stones.
