Kudos to Rockler for Bench Cookies
>A. They hold a work up a comfortable distance from the bench.
B. They grip reasonably well - I used them to hold up my seat blank while grinding and sanding.
C. They are light weight and quite portable.
D. They leave no marks.
E. If you have a 50% off coupon, they are quite inexpensive.
Re: Kudos to Rockler for Bench Cookies
Gary Smyth
>If you live near a hockey rink you can likely negotiate as many used hockey pucks as you like for $1.00 or less each. If you don't like the way they stick, spray adhesive some "knobby" drawer liners to the bottom. Much less expensive and they provide identical function.
Re: Bench Cookies
>I make mine from 3/4" scrap with a 2-1/2" hole saw or other shapes as needed, a bit of knobby rubber, and some contact cement.
Update
Gary Smyth
>Check ebay. Used Hockey pucks. 50 for $35.00 at this posting.
4 Out Of 5 Ain't Bad
Dave's Not Here
>I have recently seen some reports that if you leave your work sitting on the cookies too long they will leave a circle mark. Not sure why that is but on the bright side the marks are also said to be removable.
I also make my own for about 50� each.
Re: Bench Cookies
J.Roberts
>If you have to finish both sides of a workpiece, I made mine from some leftover 2 inch dowel. I cut the dowel into 1/2 inch pieces, drove a small finishing nail in the center of each, leaving about 1 inch sticking out . Cost, about the price of 20 finishing nails.
Fine  For Chair Legs
>But I wouldn't want nail points and scratches in a finished surface.
The textured rubber does tend to loose its grip when it gets "filled" with fine dust, but washes off with a little water. Biggest issue is that these things are not great if you're moving the piece around because then you have to move the pucks as well. For that I use a piece of old carpet foam padding.
