Dovetail Jig Setup
Dovetail Jig Setup
Dovetail Jig Setup
Mike V.
>I was wondering if anyone could offer some advice on a problem I�m having. I have a dovetail jig (Central Machine), the pins & tails can be cut at the same time. In the setup procedures it mentions taking the vertical piece of wood and shifting it �one slot� (template) to the left. Thereby, the vertical and horizontal pieces of wood are offset now (1/2"). After running the router through and subsequently trying to put the two pieces together I�m finding that the pin and tails don�t align. They're offset by one pin & tail.
I�ve tried shifting the vertical piece of wood to the other side and then tried centering on the horizontal piece and still keep coming up with misaligned pins & tails by one slot (1/2"), mostly offset by one slot. I�m at a �brick wall� now and can�t figure what I�m doing wrong.
Does anyone have any suggestions or tips? I can provide pictures & instructions via email if needed. Thanks in advance.
Re: Dovetail Jig Setup
Lee Schierer McKean, PA
>My dovetail jig (Rockler) automatically offsets the vertical pieces with the tails 1/2" to the side so that you cut the mating corner pieces simultaneously. There are built in stops for this. The only adjustment needed is to center the pins and tails on the drawer side so the spacing is even.
If your guide fingers are on 1/2" centers then you want to offset the vertical board 1/2" so that the edge of the tail is aligned with the edge of the slot it will fit into at assembly time.
Lee
Mike V.
>Thanks Lee
I went and did another test and discovered that you're correct. My instructions stated moving to left "one comb" and I wasn't too clear on the meaning. However, now I am....Thanks again.
