8" dust collection
8" dust collection
8" dust collection
Curt Snyder
>I have a Powermatic 1900 3 hp 2 canister kit. Is that big enough to run 8 inch main runs and then reduce down from there to either 4 or 2 inch at the tool. Dont wanna go to big hoefully eight isn't
Re: 8" dust collection
>Your performance will depend on the length of duct you use along with the duct design and instal. Your 14" blower will take an 8" duct, but to maintain velosity, you may find that you'll have to drop to 6" duct at some point down the line.
As a side note, trying to pull through a 2" line will be largely a waste of time; it will just starve the system of air unless you're pulling 15 or 16 of those 2" hoses at the same time. Remember, to maintain maximum velosity in the ductwork to move the dust to the collector, you need to suck large volumes of air. The collector is a fan, not a compressor.
>Mark is right.
You must maintain enough air flow to keep the debris moving. Think of your heaviest particle. There must be enough mechanical energy in the air stream to make that piece fly all the way to the collector drum/bag.
I also agree that two inch hoses are probably useless. If you only open a two inch port the air flow in the 8" trunk will be so slow that all butt he lightest particles will fall out in the bottom of the duct.
Having said that, I use a two inch hose on my ROS. It does a pretty good job of collecting the dust, but the dust is so light that it flies pretty well. I have noticed that when I open a port or two after using less air flow, I can hear the debris being blown to the unit. I also find debris lodged in the system in areas with reduce flow. I think what happens is the system streamlines itself and deposits debris, making the pipes smaller until the optimum size is "found".
Check Bill Pentz site. I am sure he has calculators on there that will help you.
Re:  Pipe Dust
>Barry, if you've got duct "collecting" in your ducts, you need to clean that out. Ducts should be kept free of debris. I have several clean-out/inspection fittings in my PVC ducting for just this purpose
Re:  Pipe Dust
>The only place I have a "chronic" problem with this is in a stub out I left for a future run. I used a Wye instead of an Elbow and then capped off the stub. Someday I may put a pickup for my lathe but so far have not done it. When I remove the end cap, the "dead" leg is full of dust. I think this is a vortex effect. You can tell what I was working with. Layers of walnut, maple, pine, cherry. Sometimes there is a little build up at the reducer fitting for my TS, but that just seems to fair out the step. I do have clean outs and access ports if I need them.
Tip
>When putting an unused wye in the line for future option, do not cement it, and point the stub up toward 12 o'clock, then seal the joint and plug with tape. This will prevent the dust from accumulating in the unused fork. To put it into service, simply remove the tape and rotate the fitting in place to make the new connection.
