Drawer bottom question
Bill Grumbine (Kutztown PA)
>Looking for experience here, not hypothetical. I am building some storage cabinets for the shop. I have 14 drawers to build that will be 29" wide and 18" deep. Depth will vary from 5" to 3". While I do not plan to stuff each drawer full of iron, there may be some of that, and most of them are going to hold tools and accessories.
Before I start cutting plywood, should I plan for 1/2" thick bottoms, or will 1/4" bottoms be sufficient? Is there someplace I might find a load table that will make sense to a non engineer round thing maker like myself? :D
Re: Drawer bottom question
Brent Smith in Montreal
>Hi Bill,
I made all my drawer bottoms 1/2". Some of the drawers are larger than you antisipate your's to be and filled with iron :) . So far no problem. I feel that for the shop, overkill the first time around, is better than wishing you had.
Fred Davis
>3/8ths certainly wouldn't hurt and 1/2" will hold anything you would have in the drawer.
If your using drawer slides ,go for 100 LB rating , fully extended.
I don't do round thingys , but I do a lot of drawers.
FredD
"Shop"  Draws
>I use 1/2" ply. I could get away with good 1/4" stock but sooner or later the heavy tools seemed to migrate to the middle, and bottoms began to bow. Plus good 1/4" stock is almost as expensive as 1/2" B/C.
I also line tool drawers with the thin black form sheets that mechs use all the time.
I cut 5/16" slots and make the tenons on the table saw with a sacrificial fence.
>Good Afternoon Bill,
It seems that the larger the depth, the more prone that drawer will be towards heavier loads. Normally, I'd say 1/4" would provide plenty of strength, and I'd do that for the 3 inch doors. For the 4 and 5 inch drawers, I'd probably go 3/8ths ply or solid. Half inch is a lot of plywood bottom. Whatever you do, I'm sure it'll be "top drawer". 8)
George
1/4 will work, but 1/2 will be better
Andy Wright - Allen, TX
>I put in 1/2" bottoms for all of drawers in my shop and they are great
>Bill, I agree with all of the above. That Is Yes, No & maybe.
I think all my shop drawers have 1/4" bottoms. Some are as big as you are discussing and all have worked fine for as long as 30 years.
In spite of that, the quality of the plywood has appeared to degrade over the years. I might go with the 3/8" BC stuff from the borg. I would make it captive all the way around or if it were under the back of the drawer, I would glue it carefully and screw or staple it thoroughly. That is, if it is supported thoroughly all the way around any of them will be fine.
As I said, 1/4" pretty good quality plywood has worked for me. I am even more sure 3/8 will work and I think 1/2 would be over kill and a waste of space and money. I would glue it into the rabbets all the way around.
I also agree with the idea of buying drawer slides or runners with a substantial over rating. 100 lb runners are significantly better than 50 lb runners.
Lee Schierer McKean, PA
>When I built the drawers for my shop I use 3/8" plywood for the bottoms. They were about the same size as those you are asking about. In a single drawer I have 3 hand drills, a jig saw, a belt sander, ROS, a craftsman router, a circular saw and a few other odds & ends. No sagging or failures so far. 1/4" might work, but it is a bit light for tools. If you were drop a gouge, it would likely go right through 1/4".
Lee
P.S. Bill any picnics in your future??
At One Time I was A 155 Pound Runner
Don't want to refute my own arguement,but...
>I too WAS a 155 lb runner and now that I think of it I was a better runner at 155 than I am at 185. But, I guess it is usually true that a 25 year old runner is in better condition than a 60 year old runner.
Phil In Connecticut
>These shop drawers are approx. 29" wide x 24" deep, and were constructed with 1/2" baltic birch. You could probably get by with 1/4" if you are sure that you won't be loading them all that much (for example, I have a similar drawer, similar size, with 1/4" bottom that is filled with router bits and shows no deflection, but it is only a few inches deep). With the 1/2", there will be no doubt that it will handle just about anything you would want to put in it.
>Thanks for the replies everyone. I know I will be safe with 1/2" stuff, but I was thinking of avoiding weight and gaining space. The plywood I use for this stuff comes from a commercial plywood supplier, not the Borg. Not only is it a better quality, it is often cheaper for the same stuff - i.e. birch ply. I am blessed in that I have Russell Plywood, Industrial Plywood, and C.H. Briggs all within 40 minutes or less of the shop.
>Lee, no picnic this year. We have been doing so much running with two grandchildren and such that time is tight already, and it is only January!
>Phil, thanks for the picture. This is very similar to what I am doing.
Knowing you, Bill....
>... you will sooner or later be stowing heavy stuff in these drawers. In my career as a custom cabinetmaker, I used 3/8 ply a lot. I almost never used 1/4" because, even though it will likely carry the weight of a drawer this size, it can bow easily over spans like these, and it has a tinny feel to it that I could never stand. That said, if weight and space (c'mon now. :) are an issue, engineer it to the lightest spec possible. For the shop, I wouldn't look back; I'd use 1/2" and not worry about the lost space. Pricewise, it's neither here nor there.
1/4" of quality plywood will be fine
Bill Tindall
>1/4" "Baltic" will be stronger than the dados holding the panel. Test this claim. Put an equivalent piece of plywood on 4 blocks simulating the drawer bottom captured in dados front, back and sides and load it as you see fit. I predict any reasonable load will flex it only slightly. On the other hand loosing another 1/4" of drawer height is not much price to pay for peace of mind. You may want to use this cabinet as a step ladder some time.
Re: Drawer bottom question *LINK*
Grant Wilkinson
>Bill
I went with 1/2 on my new ones. I had 1/4 in my old ones and had sagging problems with those that held heavy plug in drills, belt sanders and routers.
Here is a link to a site that will compute sag. It's directed to shelves, but some of the same principles apply.
Sagulator
>Thanks for the continued replies guys. Ellis, you are probably right. I can see me putting a hundred lbs in some of the bigger ones, even if I don't start out that way.
Grant, thanks for the link. I appreciate the numbers they show there.
Jim Dillon
>Bill,
Agree with the others that 3/8 or 1/2 inch plywood would do the trick. If you want to use 1/4 inch plywood on the less deep drawers, you might consider using a middle stile on the bottom to provide support for two separate panels.
Jim
1/4" will NOT work. 1/2" or 5/8" PLYWOOD....
Hikmet C. Sakman
>...not pressbooard, OSB, MDF... etc.
Chico
>I just got back from the plywood store with the goods to finish my cabinets. I have the plywood in the barn, but the doors are frozen shut with almost two feet of global warming up against them. It was easier and faster to drive into Reading and get some more. There will always be more cabinets to build.
Better safe than sorry
>Good choice, Bill. Save the 1/4" plywood for your next doily cabinet. :)
I was wondering.....
>Where all our snow was this year....Thanks Bill for taking care of it for us :D .
