how do you???
how do you???
how do you???
McKay
>I use a computer a fair amount, but I have never needed to delete a certain sites cookies. I can clear all sites, but not just this one. Would someone explain how it is done? Thanks
Re: how do you???
Which Browser?
Dan Donaldson
>In Firefox, you go to the preferences and in the privacy tab, there is the ability to remove individual cookies.
In Opera, in preferences under the advanced tab, there are some cookie management choices.
Not sure about IE, but there should be something to do it. Cannot check that one as I do not have any instances of IE to look at right now.
Re: how do you???
Re: how do you???
David Yoho
>There's no need to clear all of your cookies - just any and all woodcentral cookies. If you're using a version of IE, I've found the best way is to use Windows Explorer to navigate to your cookie folder and scan through the list deleting all instances.
Look under the folder C:\Documents and Settings. Then look for the "administrator" subfolder and any other User Name subfolder. Within that is the "Cookies" subfolder. Look for any text (.txt) file with woodcentral in the name and delete it/them.
My current one looks like this:
C:\Documents and Settings\Administrator\Cookies\administrator@www.woodcentral[1].txt
When I cleared all of mine I found several of them, so look carefully.
David
Re: how do you???
Re: Where do I find Preferences?
Dan Donaldson
>I depends. In the Windows version, I believe that it is under tools in the menu. In the linux version, it is under edit.
Re: how do you???
Re: how do you???
Grant Wilkinson
>In windows,
using Firefox, go to the Tools dropdown menu, then Options, then Privacy. There is a button for Show Cookies. You can delete all or any of them.
using IE, go to the Tools dropdown menu, then Internet Option, then Privacy, then click the Sites button. You can delete all or any of them there.
