OT Anybody tried Low -E window film?
>I just read about a plastic film you can apply to your homes windows to create the Low E effect. I did not know they could apply the process to plastic film. A patio door would cost about $30. It is supposed to cut heat loss substantially. Anybody tried it? Successful?
Re: OT Anybody tried Low -E window film?
Bruce, a MN Galoot
>I don't know about heat LOSS, but we use it to cut the heat LOSS in our sun room during the summer. It works incredibly well. Got it from Rob's folks at Lee Valley.
>I read that there are at least two kinds. One that blocks heat out in summer and one that keeps it in in winter. It may depend on whether you put it on the inside or the outside. And it also blocks the UV. More or less depending on how dark it is. The stuff that is nearly clear works well for Infrared or heat but not so well for UV. the darker ones work better for UV.
We have
John T
>We applied a product from Gila, called heat control film - our color choice was "light", but I know it comes in darker shades.
We used it on our master bedroom windows, which face west, and get a beating in the summer sun. The MBR was significantly hotter on summer afternoons, but since applying the film, I think the room is cooler in the summer.
I have no hard data to back it up, it just seems like its cooler up there, now.
Application was fairly easy, but definitely a 2 person job. My wife an I fumbled one piece of the film putting it up, and a small area stuck to itself - now there's as small kind of clear, kind of shiny area on the window where the film was damaged. If you're careful, though, application really is easy.
No real change in visual appearance to the window (looking in or out), either, that I notice.
Cheers.
-John-
Bruce, a MN Galoot
>We put it on the outside. Don't know what it blocks, but it save the carpet and the birds can land on the railing and not notice us taking pics.
Stuart Johnson
>I first saw it used in Denver and it took an office that was unbearable to comfortable when the sun was from the west. We had it installed a few years later in Tucson, AZ and it made a great difference. I installed it in an office in Houston and once again saw in immediate difference. I don't remember the name of the product but bought it at HD. It was very easy to install. Clean the window very, very well then spray with a water soap mixture. Start at the center and squeegee it dry. It is cloudy when applied but clears when completely dry. One thing to remember is to leave about 1/8th of an inch uncovered around the edges or you can get enough heat build up to actually break the window. One side benefit we found in Houston was when someone tossed a tire rim at the window it broke but stayed in placed. From the outside it looked like a mirror and did contribute to some inside the office when some would check themselves out.
I'm trying to keep the heat IN, not out
>I'm looking for somebody who put it on the inside to keep the heat in. I don't really don't need to block it out, at least not so much.
Re: I'm trying to keep the heat IN, not out
Alexander Grigoriev
>I don't think the reflective film helps much against heat loss. More heat retention can be achieved by using the film which makes another layer of air (kind of another pane).
Jason Roehl in Lafayette, IN
>We used a product on our master bath window that was a heavier, translucent film, for two reasons. One, we wanted something to block the view (unfortunately, that works both ways), and to help a little with heat loss, since we have single-pane wood windows with storms that are in various states of disrepair. I've noticed that it's definitely warmer in the bathroom in the winter, and not as warm in the summer, even though it's a south-facing window. The downside is that on sunny winter days, it does not allow for as much passive solar heating.
BTW, I have an infrared thermometer, and was able to immediately verify about a 20�F (I think it was that or 10) rise in temperature on the surface of the film vs. the surface of the glass immediately after installation, since I installed it on a cool, Spring evening, if I recall.
Jason
