Help Help....installing enclosed oven
Terry Alexander
>We are still building our kitchen cabinets. Plan this weekend is to build the hot wall lower cabinet. We currently have our new oven in an enclosure so we can use it. It has an MDF top (will be granite on final installation), sheetrock in the back and right side, 2/4's for the floor and it is open on the left side. When I build this cabinet, I will have a plywood partition on the left side...thus completing the enclosure.
The installation instructions say to install the oven in a completely enclosed area. When we use the oven now, you can just barely touch the sides for a second as they are very very hot. We are deeply concerned that we might be creating a fire hazard if we completely enclose with plywood.
OR....does the oven have some kind of recirculating fan that, once enclosed, it draws in the residual heat and reuses it?
Confused and concerned and would appreciate any comments and/or suggestions.
As always....thanks in advance.
Terry Alexander in West Texas
PS: Ellis.....really like the new "feel" on the board.
Re: Help Help....installing enclosed oven
Re: Enclosed Oven
>Terry,
Either your oven is rated for "0" clearance or it's not. This you must get from the book and/or the manufacturer, and they will also tell you what materials are approved for the enclosure. However, even zero clearance units provide for minimum rough openings; you never have the cabinet walls actually touching the oven so there's always some airspace around the unit. Your appliance came with specs as to installation. Please make sure you follow them to the letter; they are not "negotiable suggestions." Many ovens, especially convection models, now have a thermostatically controlled fan that keeps running after the oven is turned off to cool off the whole appliance.
Dave Bair, Eaton Rapids, MI
>I installed an unvented, fully-enclosed GE double oven 3 years ago. There is a fan that keeps the electronics cool but that was clearly explained in the instructions and the user's guide. I've had no problems with cabinet heat or deterioration, even when the self-clean feature is used. The 3/4" plywood sides get barely warmer than the ambient temperature. My concern was the use of 12-ga. wire by the manufacturer in the oven itself. I used 6-ga. wire and a 30 amp. circuit for my part of the installation. I was sure that the first time we ran both ovens at once or ran the self-clean feature, the oven wires would fail. Nope, it still works just fine.
Fred Davis
>Since you were second guessing the factory's specs , you could have used #10 AWG. which is the correct size for 30amp load and saved yourself some money , not to mention ease of connection.
FreDD
Re: save some money
>The 6-ga. was already there, I did replace the existing 40-amp breakers with 30's, per the mfg's specs. My concern was that the heating elements are factory-wired with 12-ga wire. It is high-temp rated, but it still seemed small to me, especially with two ovens. Guess they know what they're doing since it's still working fine.
