OT - Computer Question
Ralph Lipeles
>I am selling my Toshiba laptop. I have cleansed all of my personal files but have not been able to figure out how to remove my name from where it appears after the laptop is initially turned on. I appreciate any help that I get.
Re: OT - Computer Question
Ralph Lipeles
>I forgot to mention that the laptop is running Windows XP.
Andy Lincoln,in Dearborn MI
>Ralph,
Try this: start--control panel-user account. change the name on the account to user,owner,etc.
I assume the screen with your name is the windows log in screen.
hope this helps,
Andy
Jason Roehl in Lafayette, IN
Yes and No
>That will change his name on the start screen, and in most places where one would interact with the account name in XP, but it doesn't truly change the name on the account--his original name will still be in the file structure.
The only real way to get rid of your name on a computer is to wipe the hard drive (there are various levels to doing this, also, from a simple re-format to a Dept. of Defense standard of wiping where all zeroes or ones are written to the hard drive), then re-install WinXP (or another operating system).
Jason
Re: Yes and No *LINK*
John McGaw
>Agreed. Best bet is to run a program that "nukes" the entire hard drive and then re-install a fresh copy of the operating system. Of course it would behoove anybody thinking of doing this to know beforehand that (s)he is in possession of of niceties like the proper re-install CD and a valid key. I can recommend the program DBAN (Darik's Boot and Nuke) as a way of totally clearing the computer. Using one of the simple fast erase modes is entirely sufficient; the DOD-approved Gutmann method is massive overkill.
http://www.dban.org/download
Grant Wilkinson
>Ralph
There are three different entries in the registry that hold the computer name, registered name and organization name. You can change all or any of them. As the others have said, if you want to wipe the drive, you can do that, too. But, if you want to keep an installation of xp on it, you don't need to re-install xp to change the names.
PM me if you want some direction on editing the registry. Or, google "windows xp" +"name change" + registry.
Before you wipe your hard drive...
Ed Beck
>Make sure that you have an Operating System CD (Windows XP in your case) which you can reinstall from. If it says "Upgrade" on the package then you can't install a fresh copy from it, you need to have an OS on the system in order to use that CD.
If you don't have a CD that you can install fresh from, take Grant up on his offer.
BTW - I'm in favor of wiping the drive using one of the tools previously mentioned. I use Kill Disk (http://www.killdisk.com/). And yeah, the Gutmann method is massive overkill. I usually select three passes unless I'm in a hurry, then I just do one pass. Once you kick off the wipe there's nothing wrong with leaving it alone while you go to your shop.
Re: Yes and No
Charles in Mtl.
>wipe the entire drive and re-install Windows. It's the only sure way of deleting all personal files.
Re: Before you wipe your hard drive...
Charles in Mtl.
>it may have a utility to create the OS installation disk if one was not supplied with the laptop.
Correction
Jerry Nicholson
>You can do a complete legitimate "from scratch" install of Win XP from an XP Upgrade Disk if you have an original Windows 98 or Windows 95 install disk (full install, upgrade, OEM) available. XP will ask for proof that you should be installing from an upgrade disk and you just stuff the old 95 or 98 disk in the drive long enough for XP to recognize it. A Win 7 upgrade does not work the same way.
Jerry
