my WildBlue (satellite internet) is history....
Bill Tindall
>This note is for folks that live remote from cable or DSL.
When I went on Wild Blue several years ago it was a great improvement from the dial-up I had been struggling with. There is no chance I will ever see cable in my remote area. But over time WildBlue speed has deteriorated to where at night it is about like dial-up.
Amazingly, I can get a signal from a Verizon 3G tower. They were running a special where I could try it free for 30 days and only commit to a 1 year commitment.
I have been on it for 4 days now. Most of the time I get a 3 bar signal (out of 4) which gives me 500KB of download speed. Twice I have lost the 3G signal and dropped back to something labeled 1X which downloads at about 150 KB's. To my amazement on many web sites even at the slower speed the Verizon is significantly faster than Wild Blue for loading web pages. I will be looking into an antenna to see if that improves my signal.
The moral of this story is if you live in the out back and rely on satellite for internet look into getting a connection off a cell tower. Even if it is not an optimum signal it may be better than WildBlue.
technical stuff: There is nothing wrong with my WildBlue installation. The problem with WildBlue is that they have too many customers for their capacity, especially at night. Furthermore, there is something called latency which rears its ugly head on some sites, especially my email account at Earthlink. While the download speed can be 500 KB, the latency resulting from the "handshaking" going on can slow the download to a crawl, and does on many sites. I think the big improvement of the Verizon is the result of improved latency. If an antenna boosts me to the Verizon max of 1.5MB I will be especially pleased.
Re: my WildBlue (satellite internet) is history....
>Bill, not to "down" Verizon, but before you commit you might check to see if Sprint's 4G service is also available to you through that same tower.
Dale Stansbery
>Bill, if you're getting 3 bars without an antenna or even the little rinky dink 3 dB one available from Verizon, a good antenna should be a large help. I'm using a Wilson 13 dB yagi that's about 30 inches long. I found Solidsignal.com to carry the best antennas at the best prices. Just google 3g antenna and your choices should appear. You'll need to know what band you're 3G is on or get a dual band antenna.
Also, if you want to see your actual received signal level, click on your VZAccess manager, hit "control-D" and use the password "diagvzw". When the next window opens, select "field test". The resulting table lists the characteristics of your connection. The fourth item CDMA RSSI is your receive signal level. You can use this to aim a directional antennal. If you look on down the list to Band Class, you'll see if you're receiving in the 800 MHZ(LO) or 1200 MHZ(HI) band width which determines you antenna band requirement. If you have 3 bars now, you probably have a received signal in the low 90's. With my Wilson antenna, I improved my RSSI by 10 DdB over the little Verizin antenna, and that's with the antenna sitting beside my computer. If I'd ever get it up on the roof and aimed properly, It would be even better.
Another tidbit. If you have a Verizon CDMA phone, you can plug your antenna into it and read your signal strength in bars.
thanks a bunch for all the helpful info..
Bill Tindall
>When it is not foggy I am at -83 db, and in the fog this AM I had dropped to -90. At -83 db my download speed is about 500 KB.
