OT Honda Ghost radio ????
Frank on Chestnut Hill
>All you Honda Folks,
The radio on my 05 Honda accord has been coming "on" in the garage after it key has been removed from the ignition. You leave the garage and hours later you hear something and there it is. My usually knowledgeable Son gives me the "yea right " quip. If I can't fix it I guess I can sell tickets and let non-believers sleep in the garage for the experience.
Help,
Frank G
Re: OT Honda Ghost radio ????
Galen Vetterick--Ames, IA
>Frank
The ghost in your Honda is not the only haunted car. I had a 1990 Chevy truck that the radio played at a very low volumn and you could not change it but the the ignition and radio were both OFF. The dealership checked the ignition switch, looked for an accessory relay that maybe did not drop out. It did not always "play" so hard to find. When they said it might be grounded I wondered what they ment since there was no power to the radio by the normal hot wire and yes it is grounded. They even checked to see if the dash metal was "hot" by a shorted wire.
End result they could never "fix" and in about three months it stopped on it's own. Never notice any side effect or fire from melted wire somewhere.
Good luck!
