number of plies in plywood, do they make a dif?
woodenleg
>A friend of mine and I were talking about which plywood would be stronger, Apple ply (baltic birch) or standard 3/4 plywood. He thinks that standard plywood would be the strongest, while I think it is the number of ply. We were comparing 1/2" Apple to 3/4 standard. Any thoughts or sites to go to.
Thanks, Dave
Re: number of plies in plywood, do they make a dif?
>It depends. There are too many variables - manufacturer, glue, wood, etc. Is it a veneer core plywood, a MDF core plywood, a chip core plywood?
What is his "standard" plywood? Is it the 3/4" exterior ACX grade from the big box store?
>JL is right. Too many variables. And the question is incomplete. Strongest in what sense? Bending the sheet in the way roof sheeting bends between the rafters when you walk on the roof or in the sense of a plywood beam?
Some of it would have to do with the orientation of the plays. In the roof example, the plies that run across the rafters/trusses contribute significantly more than those that are parallel to the supports. The plies further from the center of the sheet (face Plies) contribute more than center plies. In a beam, you only count the plies that run lengthwise. Any plies that are vertical don't add much to the strength.
Obviously the strength characteristic of the wood itself applies, as does the glue, and the quality of the wood and ETC.
Number of Plies
Howard Acheson
>The biggest benefit to more plies is that more plies generally result in more stable sheets. Strength has little to do with it. There are two general catagories of plywood. One is "construction and industrial". This type is the covered by a standard that is primarily concerned with strength when used in construction. The other is "hardwood and decorative" which is covered by a different standard who's emphasis is on appearence.
Jesse Cloud
>I think the reason we woodworkers love Baltic Birch has little to do with 'strength' as such. The crappy rippled, voided stuff at the big box is still pretty strong, just not consistent or stable. The high number of alternating direction plies in Baltic make it flatter, less likely to warp, and less likely to have huge voids, all really important features for high end cabinets, but less so for sheathing.
Fred Davis
>Jesse,
your pretty much right except for plywood used for sheathing.
Your right in thinking that Baltic is better then "standard" if your using stiffness for comparision.
Plywood used for roof sheathing for instance, in 1/2" thickness comes in "three ply" and "five ply "
The five ply is more desirable from a strength and resistance to sagging specification, also costs more , but well worth it.
When I have a skip sheeted roof redone , I specifiy 1/2" CDX five ply for overlaying the skip sheathing, this gives a much flatter appearence to the roof plane and increases the life of the shingles.
For directly overlaying the rafters, I have used 5/8ths CDX T&G plywood sheathing where the roof incline is less then 6 in 12 and snow load is common.
The construction industion has pretty much given the roof sheathing over to OSB (oriented strand board) commonly called chip board and I think in some areas of the coutnry they will be sorry they did, years down the line.
As a last hint to ply ratings , you can buy cabinet grade 3/4" plywood in five , seven or nine ply.
The more the plies, the more it costs.
The nine ply has the flattest surface and lack of ripples of the three.
Baltic Birch made in Finland and sold here has no voids at all.
It comes here , graded "B" , and is far superior in construction then any "A grade" made in this country , with the possible exception of Apple Brand plywood.
FredD
>My Baldwin grand piano is supposed to have 41 plys of hard rock maple in the pinblock.
How much would that cost per sheet?
