A55 Smoothing Plane
Oil finish for mahogany? Or best finish
Wally
>Is an oil finish good for mahogany? I would like it to darken the wood.
I'm finishing a blanket chest
Re: Oil finish for mahogany? Or best finish
Clint Searl, at the base of Haycock Mountain
>For the most reliable finish, if you want it darker, use a wipe-on pigmented stain, like ZAR or MinWax, then finish with an oil or water borne poly.
Clint
Re: Oil finish for mahogany? Or best finish *LINK*
David Yoho
>You can use an oil finish like Watco for sure but for a piece of furniture like that I personally like more protection. Staying with the oil theme, I like Waterlox Original Sealer & Finish. This formulation gives a medium sheen, which I like more than high gloss. I apply a liberal amount the first time, rub it in with a cloth, and wipe away the excess. Let it dry overnight and apply two or three more thin coats with a cloth.
One thing to remember about any oil finish is don't apply it to the interior of the chest because the oder will never go away and it will stink up anything stored inside. For the inside I like to use a couple of coats of shellac - Zinsser Seal Coat works great for this.
I've provided a link to the Waterlox Original Sealer page for information.
Wally
>Great answers, never thought of odor inside the box!
Thanks.
Fred Davis
>Wally,
If the Mahogany tneds toward a brown rather primarily reddish color I stain it with Red Mahogany oil based stain by Minwax.
Because it is rather porus , I also fil the horizontal surface with Sherwin - Williams oil based filler.
I hear good things about Silica fillers but havn't tried them , water based I think and I don't allow water near wood I am finishing.
I use Lacquer for the finish, which requires spray equipment , so this may not be your cup of Tea,
But that's just me and I do get nice remarks on how it looks, which is one of the tests of a finish.
FredD
depends on what you want it to look like
Bill Tindall
>If you want to simulate a period finish you first need to color the mahogany , then oil and then a top coat of shellac or lacquer. Likely if you wanted to varnish the piece you could skip the oil. Coloring can be done chemically, or with dye stains, usually a combination of yellow and then something brownish. The result will look like what the "ammoniated" tray is sitting on in a post I made earlier in the week. That finish is yellow water soluble dye, then a brown, then oil and finally several coats of amber shellac.
I consider oil a near worthless finish by itself unless you are finishing gun stocks, and especially so for a formal wood like mahogany.
lacquer in spray cans work ok for small things
Bill Tindall
It depends on.....
Howard Acheson
>... the "look" you want. Mahogany looks nice with most any finish. Your first decision is whether you want a somewhat informal look of an in-the-wood finish or whether you want a more formal look of a smooth film finish.
If you want the less formal finish, an oil/varnish is an excellent finish for mahogany. You could buy Watco or Minwax Tung Oil Finish (neither contain any real tung oil, BTW) or, even better make your own. Mix equal parts of your favorite varnish or poly varnish, boiled linseed oil and mineral spirits. Wipe it on heavily, let it set for 15-20 minutes and wipe off all the excess. Let it dry overnight and apply another coat using 4/0 steel wool. Again wipe and let it dry. You will end up with a soft luster and will be able to see and feel the grain of the wood.
If you want a more formal appearance, then you want to use a film finish. There many choices here but I prefer a non-poly varnish like Waterlox Original or Behlen's Rockhard. Both are phenolic resin varnishes and being dark amber, will show off the grain well. While it's confusing, Waterlox Original Sealer/Finish is the same product as their Gloss and Satin. It's just an in-between sheen. Any of them can be wiped on.
For the most formal "look", you will want to first use a grain filler to get a perfectly smooth surface. Then apply your film finish.
Again, do not apply any oil based finish to the inside or any cloth item stored inside will be permeated with the odor of the finish.
Test your plans out on scrap. Never let your project be your learning curve.
Re: It depends on.....
Wally
>Thanks to all who have responded.
I am looking for the less formal finish. I would have used the oil on
the interior! Thanks for that eye opener!
