What Is This??
Frank in Colorado Springs
>Anyone recognize this? A friend found it at an auction.
What Is This??
If memory serves...
doug f, san clemente, ca
>me correctly, a HUGE assumption, I believe it is a clock winding key. Haven't seen one in years, but the one I recall reached a mechanism that was set deep in the case.
Don't forget I'm old and feeble of brain.
Doug
Re: If memory serves...
xeddog
>Looks to me like a valve lapping tool for antique cars.
xeddog
Ken Oakley-Sunny St. Cloud,Fla
>Definately a valve lapping tool
Colonoscopy probe
Clint Searl
question
Dan Donaldson
>When you turn the crank, does it rotate or go back and forth?
Re: question
>I believe the answer on these - not sure of this particular model - is a combination - oscillation coupled with slow rotation. That, at least, was the proper technique when using the hand tool version, which consists (consisted? Not sure if they're even still sold) of a suction cup on the end of a wooden handle. You sandwiched it between your flat palms and rotated the handle by rubbing your hands back and forth, slowly working it around.
Wandering OT, it's kind of amazing the number of automotive maintenance tools that are no longer useful on the modern car. I cleaned out my auto tools drawer this last summer, giving much of it to my son (who believes that any car built after 1960 or so - other than his grandfather's 1980s Mercedes diesel - is Just Flat Wrong, and whose daily driver is a 1951 Chevy Carryall). I still have the box with the timing light, dwell meter, and so on, but am considering cleaning that out, too.
valve lapping tool has suction cup end
Dick Coers------WebKitFormBoundaryv54aV+RmMmGf6euZ
Re: What Is This??
Joanne in Pt. Pleasant, PA
>That's the infamous left-handed smoke shifter!
Re: What Is This??
>Thanks, everybody. Yup....it's an old valve grinder. I found some similar pics on internet auction sites.
Don, I don't know how it turns/spins. I try and get a hold of the owner to find out.
Re: Colonoscopy probe
Bill White
>Clint, I may never be the same again. And as for your choice of medical equip......
Bill
Re: not always
wb
>Very common practice in the distant past to have two small holes cast in the top of valves. The purpose of which is to accept the spanner pictured in the end of the valve lapper.
Don Wurscher
>Used one of these many times in my Dad's shop, his oscillated back and forth.
