REAL MILK PAINT
I didn't see this in the FAQ
Chet Kloss
Chet Kloss
>I wanted to make an adjustment/change to my profile (add some text and a picture) so I clicked the My Profile link. I made my changes and clicked the SAVE button. I then got an error message saying the profile wasn't saved because one already existed with that email address (which is true) and I use use the Edit Profile option. Unfortunately, I can't find the EDIT PROFILE option.
Lil' Help?
Thanks,
,,,,,,,,,,,,Chet
Re: I didn't see this in the FAQ
del schisler
>http://www.woodcentral.com/cgi-bin/messages.pl/page/1/md/phvN3z7w this is where you can change it i belive this is what you are looking for ???
The reason
Dan Donaldson
>I looked at your profile and am pretty sure that the reason is that the profile manager matches up a name and an email address. The profile with your name has "Chet Kloss from Livonia, MI" as the name, which, to the manager is different from "Chet Kloss ". You can delete your WC cookie, then post with the name as it is on your profile to set a new cookie with that name, then it would allow you to edit the profile with the complete name. You should be able to edit the name in the profile at that point and then update the cookie to fix it.
Chet Kloss
Same result unfortunately
Chet Kloss
Chet Kloss
Bummer - that didn'twork either
Chet Kloss
