Expanded
>Let�s start with the materials:
�Spalted� wood. Spalting, in any kind of wood, is, simply, rot. The coloring (blue /black lines and different shades) is the result of the action of several fungi who�s �job� it is to decompose wood and recycle its nutrients into the ground. The lines, caused by mineral deposits, generally mark the edge of the decay process. Thus spalted wood, depending on where it is along the line from solid to useless sponge, will have a wide range of density; far more than burl or other figured grains, and will absorb finishes in wildly varying rates. The first step, then is to even out this density and porosity. The classic way to do that is with a solvent finish sealer like shellac or lacquer sanding sealer.
Shellac / SealCoat: Shellac is a resin secreted by a certain variety of insects, mostly found in India and Southern Asia. It comes in various forms and tones and in various stages of refinement. I only use 100% dewaxed shellac for reasons detailed further on. SealCoat is a proprietary product of the Zinsser Company and is a uniquely processed dewaxed shellac that is almost water-white in color. If a finisher prefers to mix fresh product, the Ultra Pale grade of shellac flakes will come close to SealCoat�s lack of color. Maximum paleness is important because when mixing dye, the color of the resulting film is easier to control with a water-clear base.
TransTint Dye: These are alcohol dissolved dyes made by Homestead Finishing Products. They come in a wide range of tones as well as primary colors. They can be used to make custom alcohol-based NGR stains, and because they are alcohol based, can be added to shellac, epoxy resin, and waterborne finishes to make unique coatings, glues, and fillers.
Okay, with our terms defined, lets go to JL�s piece. I can�t see it, of course, but that�s not important here.
First job is to control the absorption of the wood�s surface without changing the color, but still bringing out the grain. SealCoat is excellent for this use. Straight from the can, it is a 2 lb cut, meaning that 2 pounds of shellac were dissolved in a gallon of alcohol. While this is fine for some applications, it won�t sink into the wood as well as a lighter mix and thus won�t seal the less dense wood as well. I prefer to thin it out by using 1 part product to 1-1/4 parts alcohol. This mix is then applied by padding or sponging several light coats on the surface, then hitting the softer sections again. What you�re aiming for here is a uniform sheen to the wood surface. This will usually signify that the surface is fairly evenly sealed. When fully dry, a light hand-supported sanding with 400 or smaller grit is recommended here.
Step Two Toning: With the wood sealed so that you can control how much stays on the surface, you are in a position to make very fine adjustments to disparate color areas by using full strength SealCoat shellac (or Ultra Pale mix) to which you may add several drops of various TransTint dye colors. [Did I mention the use of practice scrap to arrive at the colors you�ll use? Be sure to write them down in a formula book for later use.] This colored shellac can now be applied by a small fine sprayer (hvlp mini gun or even air brush) to change lighter areas in the wood to match the darker sections. Since you�re applying shellac to shellac, your toning coats will �burn in� to the sealer for maximum durability. Since the dye dissolves in the shellac, it doesn�t effect transparency of the finish film and the full character of the wood shines through.
Last Part - Top Coat Waterbornes: Waterborne finishes, once the exclusive domain of the professional and commercial makers and factories, have come a long way in the last 15 years, and the variety available to hobbyist woodworkers can be confusing; everybody seems to have their �fav.� The quality of the various formulas vary quite a bit, so it�s best to get some detailed advice by finishing pros who are using the stuff daily. Target Coatings, here in New Jersey, was the first (I think) to market a waterborne lacquer formulation that has the tremendous advantage of 100% burn-in like solvent finishes of shellac and NC lacquers. It becomes part of the layer under it, fusing into a single layer film and gives no witness lines when rubbed out. Use of the waterborne products does, however, require some care as they are very intolerant of surface contamination. This is the reason for using 100% dewaxed shellac because waterborne finishes have trouble staying stuck to a surface with wax on or in it. Dewaxing the shellac solves this issue. Waterbornes also have the advantage of allowing you to again use some TransTint dye additive to further tone the finish you apply. You can easily replicate the warming tone of lacquer or varnish, or even go to a smokey film that still lets most of your grain color and life come through. You can also carefully match the color of existing pieces that will be nearby in the room.
Caveats: There are several issues of some importance.
First, when using shellac as a sealer and toning base, you must make sure that the product is fresh, and that you keep your applications as thin as possible. The reason for this caution is that issues have cropped up with shellac �cold checking� and cracking under waterborne finishes if the shellac is too old or too thick. To minimize the risk, make sure your shellac is fresh (SealCoat has a born-on date on the can), and wait at least 4-5 days before applying waterborne finishes to allow time for the alcohol to evaporate completely and the shellac layer to thin out and fully harden.
Second. When adding dye (or any colorant) to a film-forming finish like shellac, lacquer and such, spray application becomes almost required. The reason for this is that toned finishes will produce lap marks when hand-applied by brush or wiping and they are very difficult to control.
