ammonia fuming question
Bill Tindall
>How long does it take to color wood with ammonia vapors- hour, day week?
I realize one can not answer this question exactly. I am looking for approximate value. I will be using concentrated ammonia, room temperature. Wood is mahogany.
Re: ammonia fuming question
Very Dark in 24h
JohnM in Mid Mich
>I just fumed a pair of Tabouret tables a couple weeks ago (late holiday presents...). My first and only try so far, but it worked like a charm. With a few ounces of concentrate (28%) in a baking dish, enclosed in a plastic tent, the white oak got very dark in 24 hours at basement temperature (50f). But note: as you may have read elsewhere, you can't really see how dark it is until you apply finish. I used Watco natural and I would say the color came out like the darker of the A&C classic pieces I've seen.
Craig Daymon
>I've fumed several smaller items (chestnut bowl, candlestick) using household ammonia and a 40 gallon igloo cooler. The cooler works well because it is fairly air tight. I have gotten very good, dark chocolate, results in 24 hours. The household is a lot safer than the blueprint stuff, it just takes a bit longer.
Don't forget to let the pieces sit out after fuming so they can off-gas. Probably the same time out of the tank as they were in would be a good idea. (Or until they no longer smell of ammonia.)
-Craig
I did a controlled experiment...
>Back in my magazine days, I tested the effect of blueprint (28%) ammonia on white oak at various lengths of exposure. I don't know what happened to my test data, but the gist of my findings is this: The surface effect deepens for a certain length of time, after which it doesn't appear to be getting any darker, but the depth of penetration keeps increasing for at least a day after that, and possibly longer. My hunch is that eventually, if the wood is permeable to the fumes, it will fume through and through. I think I decided that the most efficient fuming time range was between 12 and 24 hours. The surface turns gray in as little as 30 minutes, but the penetration is very shallow and rubs off quickly if you so much as try to level the swollen grain with fine sandpaper.
My first fumed pieces, back in the '70s were done with household ammonia (~5% concentration), and it worked fine. Watch out for the concentrated stuff, as one good whiff can ruin your whole day, or possibly kill you.
McKay
>I made a number of entry tables with panels that were white oak. The stiles and rails were quarter sawn red oak. The white oak went a beautiful dark brown. The red oak did not change at all. The panels were in a tent in my spray booth for about 24 hours. I used industrial strength ammonia.
Ken Oakley Sunny- Sunny St. Cloud, Fla
>I fume pen blanks,(5 1/2" by 13/16" sq), a lot and leave them in the container, fuming, for 24 hours minimum.
One useful addition...tannic acid (tea)
Craig Daymon
>There was a pretty good Fine Woodworking article (available for purchase from the site in PDF form) on fuming. I think they insist on blueprint ammonia, which I have personally found is NOT necessary and IS dangerous.
One interesting bit from the article was the use of tannic acid, or even a nice strong batch of tea, painted onto almost any wood can result in a change in color when the wood is then exposed to ammonia fumes. The article uses this technique to darken (age) cherry, darken butternut to look like walnut and several other woods. It also stated that tannic acid can be bought at the grocery store. (I think it is an ingredient used in canning jellies.) or you can just brew up a strong batch of tea, your choice what kind.
-Craig
not in my case....
Bill Tindall
>The piece contains satinwood inlay that I need to keep white. Were it not for the inlay I would simply stain it. The alternative is to mask the inlay with shellac, but there are oodlins of these tiny pieces and I'm not that talented with a paint brush. I can't even color inside the lines which nearly caused me to fail 2nd grade.
most helpful
Bill Tindall
>What you say makes sense, namely that after some initial coloring, time mostly affects depth of color. There could be another effect and that is moisture. It may well take some critical amount of water to get this reaction to proceed, which is why the paint it on approach works nearly instantly. The mahogany was very dry and there was little reaction in the first few hours, darkening considerably overnight. I added a wet rag this AM and we will see how things develop today.
All this aggravation is necessitated by the fact this piece has satinwood inlay that I need to keep white.
Re: not in my case....
Craig Daymon
>Sorry, I didn't pay attention to the fact you are using Mahogany. I don't believe Mahogany has any natural tannins in it, so fuming won't do anything for you. The only possible approach would be to give your Mahogany pieces a good coating of tannic acid and let it dry before assembly. Then fuming may give you the results you are hoping for.
I doubt very much you will get that Mission dark chocolate color from Mahogany, even with a very strong dose of tannic acid.
The candlestick I mentioned was White Oak with a strip of Yellowheart glued down the center. It worked beautifully and the Yellowheart was unaffected because it contains no tannins. (I think I posted pictures that should be in the archive somewhere. Probably almost 10 years back now, maybe more.)
-Craig
