Grain orientation for curved legs/feet
Todd in VA
>Hey everyone,
I've recently completed a refinishing project and I'm about to dig into a really big project. I've promised my wife that the pile of wood in my shop (which she stubbornly calls her garage) will turn into a bedroom set.
Part of what I've drawn up calls for curved legs on footboard/headboard of the bed. The legs will be curved/flared outward in two directions. This made me think of grain orientation. I'm thinking I should try to orient the grain so it is tangent to the peak of the arc/curve. I haven't done anything like this before though, so I thought I would ask. The legs will be thick if that makes a difference (12/4 walnut from face glued boards). I'd appreciate any insights!
Re: Grain orientation for curved legs/feet
Fred Davis
>Todd,
since your lamminating four? boards this should be considerable stronger then a single 4" thick piece, all things being equal and the glueup is tight enough.
Pick your grain and color and you may be able to hide the glue joints except for the book match of the grain which looks nice in any view.
FredD
Lots going on there
>If you're laminating your legs/posts grain orientation is going to be sort of a moot point unless all the laminates have roughly the same grain orientation (quartered/flat/rift). If you have enough wood to select for grain like that (e.g., all laminates are flatsawn), the glued-up pieces will be more natural looking because you won't have different grain characteristics presenting in the edge view.
Whether or not you plan to take this kind of care with the wood selection, I'd plan on running the glue lines East-West in most cases, because then they won't show when viewed from the front. This might vary depending on the piece and the vantage point, but keeping them uniform is a good idea.
The ideal way to make a 12/4 leg/post is to start with 16/4 and bandsaw a 12/4 blank that has the grain running diagonally. This way, all faces present a rift appearance.
Ellis Walentine, Host
can it be done?
Bill Tindall
>I don't have any experience in trying to make a curved leg from glued up stock. Can it be done and look like a quality construction and not inexpensive factory furniture? If the legs are a focal point of the piece any lack of harmony of the grain will be visible from across the room and any glue lines that are intersected by the leg surface at a low angle are going to appear very wide and prominent.
In any case I would begin with a practice leg and see how it looks. One can always buy enough 12/4 just for the legs. Adams in Morristown, TN sells turning blanks for legs and I am sure there are lots of other sources as well. Bottom line-don't put 50 cent legs on a hundred dollar bed. I say that from experience as my frugal nature has led me to make that mistake in my youth.
Good question, Bill
>In this case, I'd be careful about a couple things. First, I'd definitely try to get pieces of similar grain orientation and color for the laminations, and second, I'd try to avoid cutting through a glue line when bandsawing the curves in the leg. You can't avoid it in the face perpendicular to the glue lines, of course, but in the face-grain piece, you really don't want to dip into that glue line. Even the tightest glue joint will show witness lines that can be quite wide and unattractive and that might well show under a finish.
Jesse Cloud
>One good way to do this is with a bent lamination. You would need to make a bending form and slice thin plies from your wood. If the plies are thin and the pieces you use match well, the lamination will be almost invisible. And the "grain" will follow the curves.
Todd in VA
>I really appreciate the insights. I have several hundred bdft of walnut, that I think was all flatsawn from the same logs (I'm not certain of the difference between flatsawn and plainsawn). There's a good chance I'll be able to match up boards to keep the grain consistent. The concave curves will be outward, which may be an issue for the glue lines. On the plus side, most of my boards are proud of 5/4 (rough, but bandsaw milled), so I may be able to pull a diagonally grained blank out of my lamination (we'll see how thick it is after jointing and planing). Thanks for the help!
