Jet Dust Collector Motor bearing replacement
Dave Paine
>I have a Jet DC-1100 which is likely out of the 5 year warranty. Anyone remember the last year Fort Washington had a Woodworking show? Likely when this was purchased.
The unit has a short chirping sound when the motor capacitor has disengaged after power down. I expect this is the beginning of a bearing failure.
I looked at the manual, and as expected, the motor is a spare part, but the bearings within the motor are not mentioned.
Anyone with any words of wisdom. Take entire motor to an electrical shop, or remove the bearings myself.
I have replaced the bearings of a 1/2 HP TEFC motor on the house fan. Took awhile to pull the old ones off the shaft. I expect if I can remove the bearins, I can find replacements locally.
I do not want the DC to be out of service for long, since only a shop vac as backup.
