Joining two pieces of wood in a hat stand
Stephen
>I am in the design phase of a hat stand/coat rack, that will consist of a base, the shaft, and some hooks. I'd like to be able to break the stand down into two parts for easy travel, and am facing the conundrum of how to do it.
The shaft will be about 1.75 inch square. Each piece of the shaft will be about 3 feet long, leading to the final height of 6 feet.
I have a doweling jig, and was thinking of using a dowel as the connection point between the two ends.
Any other creative and foolproof (or at least mostly foolproof) ideas?
Thanks, Stephen
Re: Joining two pieces of wood in a hat stand
GalenV in Iowa
>Screw a hanger bolt into one section and recess a t-nut flush into the other so it is a solid metal connecton and not wood.
Galen
AZ, Colorado Springs
>If you're gluing up stock to achieve the thickness for the post, then mill facing grooves into the pieces before gluing. You can make a square or a round cavity.
If you use a core box bit to make a round cavity, then you could use a steel rod to connect the upper and lower sections, maybe projecting into each piece by about 4". Then wood movement would be less of a factor in assembling and disassembling the rack.
You could use square steel bar stock as well, but a round rod would be easier on the hands.
The two pieces would stack together like one post of a set of bunk beds.
Phil Joines Krum,Tx
>Get a wood threading kit and cut male threads on the post and female on the base.
