Re: Resaw Fence
William Falberg
>No, Barry, I was replying to the OP but screwed up (again) on the "reply" button. Sorryyyyy:@) I like your idea of putting a flat on the dowel, it's not my preferred solution for re-sawing, but under some conditions (like "exploring" found wood) it has a place; cleaner than free-handing anyway. It gives the operator a better visual reference and probably helps to steady your hands.
It's easy for me to attach the fence to the upper wheel housing and brace the frame to the table by screwing upward, as if to spread the frame, into a horizontal rail at the top. It totally eliminates any chatter from frame-flex and gives me adjustable parallelity to the blade in the most exact dimensions. I believe there are also attachment points on any saw that could connect this way and thought first about the blade guide extension brackets common to them all. Don't they all have a bolt or two in that area that could be attached to, and bracketed out, to meet the fence/post? There's no word for a full-length post like that so I made up "leaning post" because the workpiece is meant to lean against it the same way a workpiece "leans" against a fence. I don't know a better way to re-enforce fences against the inward push of feed pressure while rip-feeding tall pieces into the blade.
I think there's an after-market opportunity for the first ambitious ontrapanure that productizes a "floor-to-ceiling" modular fence system and the instructions to do so are in my upcoming book, along with how to build the whole darn saw if one were really ambitious. I'm into my own saws and don't really know much about the Delta clones so I leave it up to you guys.
There's a whole chapter on metal-work for woodworkers I hope you all read. These wooden fixtures gotta go. Aluminum is much easier to work than you think.
