Veritas - Innovation in Tools
Glue for Bent Laminations
Tom Henderson
>I am building a bow arm morris chair. The arms will be laminated on a form and are made from four one quarter inch quartersawn white oak boards. Will regular glue be all right for this or do I need another type more suitable for laminations? I have been told that regular titebond might creep.
Thanks in advance for any advice. I am just getting started on the chair.
Re: Glue for Bent Laminations
Jesper, Denmark
Jesper, Denmark
>Quarter inch will be very difficult to bend without steaming first.
You need a minimum of five laminations to avoid spring-back afterwards.
Weldwood is the glue of choice for bent laminations in boatbuliding, alternate is epoxy.
I do not know about creep in normal WW glues.
David Yoho
>I'd be prone to use liquid hide glue. It doesn't creep and you have better open time. It cleans up easily after it dries and doesn't show up under finishes like yellow glue does.
David
creep discussion
Bill Tindall
>I have no idea what the bend in this chair looks like but I have had no problem using Titebond for arcs of 1" deflection per foot . Some of what people call creep is not creep at all. Compared to an edge glued joint where there is a massive amount of lumber relative to the amount of water added at the joint, in a lamination there is vastly more water per pound of "dry" lumber. Hence, it takes a long time to dry to equilibrium the laminated piece. If the lamination is shaped before the wood has thoroughly dried the wood will continue to shrink and the glue will not. The result will be a proud glue line after equilibration that some attribute incorrectly to creep.
Alternative
>Tom,
Since you're working white oak, I'll encourage you to take a shot at steam bending the solid boards. White Oak bends very well with steam and the curve on a bow-arm Morris is gentle. Taking the stress out of the wood with steam will, I'm sure, give you a more stable piece and you won't be fussing with glue creep or lamination lines.
Building a steam box is very easy, and you'll use the same jig you make for the glue-up as a bending form. You'll need a hot plate and tea kettle and a candy thermometer. Check the Articles Section here on WC.
ditto
Dan Donaldson
I've done similar...
John in NM
>With 2 hour epoxy in a vacuum bag. I agree that 1/4" is too thick for your laminations, you want somewhere between 1/16" and 1/8". We had no detectable springback with epoxy.
I've also done curved door jambs using Weldwood plastic resin glue and clamping forms. Laminations were all 1/16" and again no springback that I could measure.
As gentle as the curve is, I think you'd be ok with tightbond or the like, but you might get some springback (or creep if you like). I don't think it would be much if at all.
What you don't want to use is something rubbery like the contact adhesive used for laminate counters and sometimes veneers.
Dave Bair, Eaton Rapids, MI
>Weldwood Plastic Resin Glue is the stuff...if you can maintain at least 70� in your shop.
Tom Henderson
>Thanks for all of the good advice. It's obvious that there are several ways to skin this cat, as is usual with woodworking. I do appreciate your help.
Bruce, a MN Galoot
>I was once advised that there is something "magic" about using a minimum of 6 laminations when making a glued lamination. I had tried using both titebond and weldwood with 4 lams and got springback, a minor amount, but springback nonetheless. But I've not had any springback using six or more laminations, using either titebond or weldwood.
