OT Wiring Smoke Alarms????
>In new houses the smoke alarms have to be connected together so that they all go off at once. They use the red wire in a three wire cable for this. But, I thought they were available that "talked" to each other through the regular wiring and did not require the third wire. Anybody know if any such thing is out there? Blue Tooth? whatever?
Re: OT Wiring Smoke Alarms????
John in NM
>I've never heard of a system working this way, but there's no reason it couldn't. I'd guess the engineering involved in designing and building units to do this isn't cost effective when you can just run a small com wire to connect all the standard smoke alarms. I understand that the com signal they use is 9v so that they'll still function correctly if on battery backup.
Lee Schierer - McKean, PA
>I know that First Alert sells some that connect wirelessly. If one goes off they all do. No need for wires. I saw them on the shelf at the local Borg, but don't recall if it was orange or blue.
Lee
