We value your privacy.
>I have posted before about Rechargeable Mag Flashlights that I have plugged in in my car. I have had them in the car and previous cars for years without problems. Now the car battery goes dead. I remove the flashlights to prevent the car dying, but that is a PITA because then I need the lights and they are dead. My question is about the flashlight batteries. I think they NiCads. Does the fact that they go dead in less than a week indicate they have developed internal shorts or whatever and should be replaced? Could this also be the problem with the car's battery? The flashlights keep draining power even after they should be fully recharged? Any way to test the batteries? They have five half sized D cells in them.
I can't help with your original question, but your concern about the light being dead when you needed it brought to mind a flashlight I read about recently. It's very expensive, but fully recharges in 90 SECONDS. You wouldn't even have to keep this one plugged up - you could be ready to go almost any time.
>Rechargeable batteries, all types, have a finite life and if they don't hold their charge as they used to then they are done. There are tricks such as putting in the freezer, zapping with a big capacitor, even zapping with a welder. IMO, they are all a waste of time in 99% of the cases and you are better off to just get new ones.
The circuits and thus the characteristics of chargers vary as does the behaviour of a failed battery. So it is not impossible that the charger just keeps pumping current into the battery without ever shutting off and runs your car battery down.
Rechargeable powered battery devices are great when all is well. Unfortunately, batteries are rather fickle things that can easily take the joy out of living.
>The only rechargeables that I use are for cordless tools.
The last set of flashlights I bought all use AA's. The larger one has a pack that takes 4 AAs which makes it as strong as a D cell. There is a single battery one that I can bite to aim. Since all of the rest of my stuff, camera, headlamps, etc. use AAs I shuffle batteries if I'm in a pinch.
After having chargers go bad and then nicads go bad I got fed up with the waste of resources. After the whole cradle to grave energy considerations are taken into account I believe that getting the big bundles of AA's from Costco is less energy intensive.
Using flashlights/headlamps with LEDs stretches the power out too.
>Here is the link I have done this and it work's battery's still working And have done this to other fellow's battery's also Dam near as good as new Will get you by real good
Nicad batteries often die in such a way that they won't take a charge and have zero voltage. This usually means they're shorted out by crystal dendrite growth.
Here's a method of bringing them back to life by zapping those shorted crystal dendrites away with too much current and/or voltage. We'll use a welder as a power source. You could also use a car battery, a DC powersupply, or almost anything with some voltage. Charged-up capacitors are popular for this because you can get a very fast pulse out of them and still limit the power. it's a lot safer that way. Speaking of which,Do not zap nicad or NiMH batteries! Zap only individual nicad or NiMH cells. A battery consists of several cells connected in series.
Instead of an arc welder, you can use a car battery or a big capacitor. With a car battery, touch the cell's terminals (plus to plus, minus to minus) only briefly so the cell doesn't explode.
I use a capacitor rated for around 500-5,000uF and charge it from low voltage DC source (a power adapter works) and a resistor in series (protects the source from high-current damage), again plus to plus, minus to minus. The capacitor has to be rated for at least as much voltage as the source (if you plan to use a telephone receptacle, that would be at least 50V). I touch the capacitor leads directly to the nicad or NiMH cell's metal for maximum current, and I recharge the capacitor and rezap several times until the arc weakens, indicating the internal short has cleared.
Recharge the battery immediately after zapping.
Zapping
Actually, I don't think that putting 12 volts to an 18 volt battery for a few seconds is dangerous. After doing it, both batteries took a charge, and they're working again, putting out 20 volts when fully charged.
these may be trick's but it work's When you are short on cash Works for a long time And it is free my 3 cent's inflation
