OT-JAVA
Ken Oakley Sunny- Sunny St. Cloud, Fla
>Could someone please explain what JAVA is and do I need it on my PC and why? I have tried to understand what I read on the internet but it might as well be written in Greek. I wish I was smart again.
OT-JAVA
Re: OT-JAVA
>Java is essentially a very complex programming language that does a LOT of things. You need it on your PC so that you can "see" a variety of things using your web browser.
As an example, the Chat Room uses Java. It allows you to put "emoticons" (smiley faces, etc.), colored script and other things in your text while you are typing. It regulates the font size, shape, etc. It controls the size of the "box". It allows you to copy text.
Java is more "interactive". It allows a lot of interesting browser features.
Re: OT-JAVA
Dave Paine
>As another poster stated, Java is a programming language which used to be more popular to be used in web pages some time ago for creating scripts - little applications to open windows, run video etc.
I recently had a web browser performance problem. Pages were taking too long to open, or would hang. One of the recommended actions was to remove java. It seems it is not often used these day. So I did. So far I have not noticed issues with web pages.
If you have installed java, you will get little reminders now and again to update the java version. Probably good to upgrade if it is being used.
It is possible for some application installed on your PC to be based on java, since it is a popular programming language for applications. Hence the original reason for web page scripts.
I write business rules for an application at work which uses java. My application would not work without the separate java "engine".
The benefit of java to a person writing an application is not having to pay fees to Micro$oft to purchase .Net, Visual Basic, etc.
Some research would indicate that
Frank in Colorado Springs
>Java is the most popular programming language in the world .
It is sometimes confused with Java Script, a lightweight scripting language. You need Java on your computer because many of the things you see on your computer, take Amazon.com for instance, are all written in Java. The Java on your computer is an 'interpreter' that recognizes Java programs, like Amazon.com, and translates them into useful information like pictures and buttons that you can see and click.
Frank: a former Java Jock who doesn't miss it a 'bit'.
It's like oxygen for your PC- you need it!
steve antonucci
>Others have covered this already, so I won't beat it to death. If you took it away, it would cause more problems than it fixed. It provides services that you use without even knowing that you are using them...
Look for the little coffee cup icon in the tray and your are using Java.
S
Guess I'll keep it--Thanks
Keep It Current *LINK*
David Yoho
>JAVA, like many other programs installed on your computer, need to be kept up to date for security reasons. Just like updating your antivirus program on a regular basis, there are other programs you probably have that need regular updates too. The updates generally address minor bugs or potential security flaws. I consider this as important a step in computer security as running AV, spyware, or firewall programs and keeping them updated.
To that end, the link below will take you to Secunia's Online Scanner. It needs Java to run but will report if your current version is out of date along with any other programs you have installed that it checks for, including Windows updates. Anything it reports on the list will also provide a direct link to download and install the free current update.
This online scanner has been a valuable tool that I use to keep everything updated. Many times we have programs we use that don't inform us automatically when updates are available. This scanner takes care of much of that and it don't cost anything to use.
Re: OT-JAVA
del schisler
>here is why
Should You Allow Java on Your Computer?
If you encounter a website with an embedded Java app, and you don't have Java installed (or enabled), you'll just see an empty space where the program should be displaying. Many sites will provide a helpful link to where you can download the Java runtime environment from Sun Microsystems, the developer of Java. Even cell phones commonly push Java at users. But what is Java, and why should you install or enable it?
Java is an operating system, like Windows or Mac OS or Linux. Java consists of many software components that work together to provide a "cross-platform environment". Essentially, that means a program written in the Java programming language will run on any type of computing platform, not just on an Intel or Apple or Nokia piece of hardware; provided, of course, that the essential Java operating components are present. That's where the Java runtime environment becomes necessary.
Java is handy for programmers; they need only write a program once and not worry about whether the user has a PC or a Mac computer, or be concerned with which browser is being used. Java applications can be embedded in web pages, cell phones, industrial controls, household thermostats, even coffee makers. So you will run into Java often.
Yes, you do need the Java runtime environment, or you will be frustrated quite often. That online game or mortgage calculator you've been looking for all day won't run without Java. So go ahead and install the Java runtime. It won't hurt, if you have sufficient computing resources.
Is Java Safe?
Java is touted as a secure computing environment, one that makes it difficult for bad guys to snoop, cripple, or take over your computer. The Java runtime forces all Java programs to run in what's called a "sandbox", a portion of computer memory to which they are strictly confined. In the sandbox, a program cannot do certain things without the user's explicit permission - like read your email or format your hard drive. But a sandbox takes up space.
Java sets up this sandbox in a "virtual machine" which consumes considerable computing resources. The amount of resources required varies according to the needs of a given Java application. A mortgage calculator won't slow your overall computing down noticeably. A 3D animated game might, if your computer is short on memory and/or processor power.
Java applications are often encountered on Web sites, and you may want to disable them sometimes. Firefox, Internet Explorer, and most other Web browsers let you enable and disable Java at will in their "Options" settings.
In Firefox, click on the Tools button on the main toolbar. Then select Options. Click on the "Content" tab and check or uncheck the "Enable Java" checkbox.
In Internet Explorer, click on Tools, then Internet Options. Select the Programs tab and click the Manage Add-ons button. Find "Sun Microsystems - Java plug-in" and enable or disable it.
When the Java runtime is running in memory, you may see a "steaming coffee cup" icon in the system tray. It may persist after you close your browser or otherwise stop using a Java application. Don't worry, the Java runtime will end itself and the icon will go away after a short while.
