Finishing Frame & Panels
mdclor
>Hi to all,
I stained and finished the panels before completing the frames to avoid having unfinished wood show when the humidity decreases and the panels shrink. Now I am ready to spray finish the frames and wonder what others do to avoid getting over spray on the panels. Is it as simple as applying blue tape to the panels or is there a better solution? Any guidance will be greatly appreciated.
TIA,
Merle
Re: Finishing Frame & Panels
Fred Davis
>I generally stain the panels and then finish after assembly .
Your concern about shrinkage also applies to the joints.
I keep the wood in the shop as low as 5-6 % thereby making any wood movement more predictable and not worry about shrinkage which is not a concern with that percentage of MC.
Fredd
Ken Krawford
>Merle,
I ran into the same problem with this desk. I finished the panels and frames separately. I glued up the 2 rails and 1 stile. When finishing time came, I just inserted the loose stile and finished the frame. When I was ready to assemble the unit, I remove the unglued loose stile, inserted the panel and then glued the unit up. Obviously this works only for cope and stick type joints.
mdclor
>Thanks for the suggestions. However, I have already glued the frames together. Guess I will cover them with blue tape.
Thanks,
Merle
>I have done three different things.
Just stained the panels and then assembled and stained the frames. At least when the panels shark, they were stained. (Fair)
Stained and applied the sanding sealer/primer coat to the panels then glues up the frames and finished the whole assembly. (Better)
Finished the panels completely and cover them with very thin plastic like a dry cleaners bag and assemble the frames around them and then finished the frames. (Better Still) This allowed me to assemble the frames and not worry about gluing the panels into the frames at the corners, even by accident. The plastic was surprisingly easy to remove. Saran Wrap worked well also.
Since you have already assembled them, I would tape them off.
