Mortiser setup with coins, where is that picture?
Ray Carson - Lawrenceville, NJ
>I had, at one time, an illustration on setting up a Hollow-Chisel Mortiser using coins. It's very useful. I believe someone posted it here on WC. Now that I need it I can't find it in my hard drive or in the WC archives. The "www" thingy has turned up a few references but not the actual pictures or 'jpg'.
Would my friends here at WC recall the colored illustration of which I'm referring to? Maybe a 'LINK' they know of. :-)
Thanks,
Ray
Re: Mortiser setup with coins, where is that picture?
>I am not a You Tube guru by any stretch but I went there and typed Hollow Chisel Mortise and found a video on this on the first try.
http://www.youtube.com/watch?v=fv-V3zLUJmA Might work, I copied it from the site while I was there. They were setting the clearance on a Shop Smith, but the same technique works for me on my drill press with the attachment.
You could also try Setting up a Hollow Chisel Mortiser.
Basically, you put a dime in between the shoulder on the chisel and the press, so that the chisel is spaced "down" the thickness of a dime, then insert the bit snugly into the chisel and tighten it into the chuck. Then slide the chisel up to the shoulder without the dime and you have the dime's clearance between the bit and the chisel.
I don't have a picture, but......
Howard Acheson
>..... here is the description.
Insert the chisel into the quill pushing it up until it's within a quarter thickness ($0.25) of being fully seated. (This is where the coin comes in). Tighten the quill. Then insert the drill bit inside the chisel until it is stopped from further movement by the chisel and tighten the chuck. Now loosen the quill (remove the quarter) and move the chisel up until it is fully seated.
Using the coin establishes the proper clearance between the bottom of the chisel and the bit. If the bit and chisel are properly set up, there should be little or no noise.
For best operation, the flat exterior sides of the chisel should be honed to a polished surface like you would have on a hand chisel. This will allow the chisel to much more easily enter and come out of the wood.
Fred Davis
>Delta and Clico , which is top of the line for Mortising chisels recommend using a Dime.
Using Howards description with a dime will give you the specs for those brand chisels.
This may sound like nitpicking , but it's their research , not mine.
Developing a routine to follow for cutting the Mortise helps also , for instance cutting the holes on either end of the mortise first, ensures you will get a straight cut square to the stock. Overlapping each cut by about half keeps the strain on the machine down and reduces the heat buildup.
In hardwoods I let the chisel cool for a minute or two between mortises.
I keep the chisel very sharp and touch a block of Paraffin wax to it along the way.
Clico makes a tapered hone that fits in a brace and fits the inside configuration of their chisel which takes all of the frustration out of keeping the bit in original condition.
FredD
Re: Mortiser setup with coins.
I do this.
I do this.
The YouTube video that was suggested in the thread of responses shows then hitting the bit with something but doesn't say what. Good advice Fred. :-)
Eventually I'll invest in these. I see that the hones can be specific for certain brands of chisel sets though. Lee Valley mentions this specifically in the ad for their "high end" sets.
The gap is specific for different brands of chisel sets, I agree. I've read this in much of my digging to find the illustration I'm looking for.
Thanks Fred.
Re: Mortiser setup with coins, where is that pictu *LINK*
Phil Smith
>Below is link to Forrest City procedure for setting up mortise chisels.
Forrest City Mortise Chisel Setup
Re: The Forty Cents Method - This is the one!
>A picture is worth a thousand words. I hang stuff like this up in my shop so it's always at a quick reference. I understood the principle, I just hate when I can't find something. Thanks Charlie.
Ray
Re: Mortiser setup - One last question.
>What if, when the chuck end of the bit is bottomed out in the chuck, and there's a 1/2" gap between the shoulder seat of the chisel and the bushing on the mortiser? Do I cut off some of the bit shank so that I can use the coin trick? Hopefully that's clear to someone. I'm probably overthinking this, however, I just replaced the cheap bit set that came with the mortiser with better ones and I don't want to burn them up.
Thanks again,
Ray
Re: Fisch mortiser info
Larry Clinton At Frankfort (Central)., Indiana
>I have the 3/4 hp slow speed Fisch mortiser. The setup information that came with the tool and/or bit set was quite simple. First insert the bit and chisel into the chuck and holder. Drop the chisel and fit a dime between the chisel shoulder and the houlder - tighten the lock. Release the chuck for the bit and while holding the dime (or any other flat object) to the bottom 4 points of the chisel, allow the bit to drop to the bottom of the chisel and tighten the chuck on the bit. Then release the lock on the chisel and seat it to the holder and re-lock. This allows the bit to extend the thickness of the dime below the chisel.
I do a lot of mortise work in very hard woods like white oak and locust, I have found the mortiser works much easier and doesn�t "squeal� if I spray the bit and chisel with Bostik Dry-Cote before I install them, and after every couple of mortices I re-spray the bit through the opening in the chisel.
>Ray, if it were me I would find a washer the thickness of a dime and with a center hole large enough to allow the bit to extend through it. Then I would lock the chisel into the up (seated position) and press the bit and washer up to the bottom of the chisel with a flat object. The final result you want is to have the bit the thickness of a dime lower than the chisel end. What this does is allow the bit to make the main hole and remove some material before the chisel cut starts while still allowing the bit to be guided at the bottom with the chisel. If you look closely at the mortise bits, they have a "bearing" area near the tip that is guided by the chisel inside diameter. If the bit is too low the bearing is not well supported - if the bit is too high there is no material removal before the chisel enters the workpiece. (It taint rocket science) As I mentioned before I have a lot less heating, squealing and required force when I lube the bit bearing area with Dri-cote. I haven't tried it but someone mentioned wax - that may work well - I know the Bostik does as I have used it for a couple years.
Re: Response from Larry & others
>I appreciate the advice on the Dri-Cote Larry. Great advice. I completely understand the coin process too.
My issue or problem is with the bit and chisel. I have the issue shown in my sketch. In order for me to tighten the gap between the bit and chisel, I wind up with a space about a half inch wide where the dime would be. So, I have to guess at the gap between the bit and chisel. Sometimes I get it, sometimes I don't.
I'm mortising Red Oak.
Re: Cut the bit. I did. - Thanks Jim.
>I just didn't know if anyone has ever done this. It seems like the only logical thing to do. LOL Thanks for the response.
Funny how we buy tools and modify them. Router lifts, cutting bits, changing solid belts to linked ones. Why then, when this aftermarket stuff is out there and they improve the equipment, why don't manufacturer's see the advantage of putting out a better product with these products already included on their machines??? :-)
My two cents worth,
Ray
Re:The dry lub trick
North of the Border
>you shared works great and it is in one of the recent tips published in one of the woodworking magazines.
