Drill Doctor XPK
Drill Doctor XPK
Drill Doctor XPK
Chuck in ND
>I picked one of these up at our local Lowes today, they droped the price on them down from $99 to $79. Anyone have any experience with this model ? The next model up is almost twice the price.
Re: Drill Doctor XPK
Andy Wright - Allen, TX
>I have had one for a while, and it works great. it doesnt work for brad point bits, but I have several twist bits that I literally saved frm the garbage thanks to the drill doctor
>I'm on the boat with these things. They do sharpen and for cutting wood they do a good job. I've saved a lot of bits. The bits definitely don't sharpen as good as new. It also doesn't sharpen small bits very well. For those I just buy new ones. I drill a lot of metal and there are times when it has saved me. You get a bit that is dull put it in the machine and finish the job your on. However they never cut as good as new and I'm not totally convinced they give you a hole that is as accurate.
Bill Tindall
>I have some model that was cheap; probably this one. It works. In fact it works so well that the fun of using it passes too quickly. Initially the diamond wheel will make a coarse finish on the drill. After it wears a bit the finish will be better but I think they should offer a less aggressive grit on the wheel.
Chuck in ND
>This model is the next step up from the entry level model. Before I bought it I looked at the model comparision chart on their website. It's listed as being an ideal sharpener for the home workshop and serious do-it-yourselfer. What it offers over the entry level model are a Variable Align System, Quick Change Diamond Sharpening Wheel ( other grits are available ), Restores & Creates
BACK-CUT Split Points, Accessory available to sharpen up to 3/4"
Drill Bits. The next model up will sharpen at 118 degree bevel and also 135 degree bevel, but at twice the price. I supose the two different degree angles are for the type of material your drilling. I'm only guessing that the 135 is more suited for wood ?
