Lunch box planer with spiral Cutter head?
>OK, I just spent a few minutes rummaging around on the Internet and did not find an answer.
Who makes a lunch box planer with a spiral cutter head? Anybody got one? What do you think?
Re: Lunch box planer with spiral Cutter head?
>Probably doable but spiral heads tend to be a lot more massive. The lunchbox would need to be built accordingly.
Bart Goldberg
Bart Goldberg
>Barry - You can get a spiral cutterhead upgrade for the Dewalt DW-735 lunchbox planer. I have this setup and am extremely satisfied with the performance.
Regards
Bart
>I have a Dewalt 733. The older one with the resharpenable blades. Wonder if the replacement head would work for that one?
Clint Searl
Clint Searl
>I have the 12" and 13" Delta bench top planers w/straight cutters. Both perform admirably, especially the 13" two speed. The only negative is snipe. Does a spiral cutter eliminate it? If not, what's the advantage?
Clint
>Three advantages I hear about.
Significantly better cuts, especially in difficult wood. Interlocking or reversing grain, curly wood, Crotch wood etc.
With multiple cutters, Each with multiple edges, if you get a nick in a cutter, you just rotate it to a fresh edge, rather than change the knives.
And they run significantly quieter.
PS
>I don't think the cutter would have any effect on snipe. That has more to do with locking the cutter head and proper adjustment of the infeed and out feed tables.
I also have a lunch box planer with standard knives and I think it does an excellent job in most wood. I have a Dewalt with the knives that can be sharpened multiple times. I sharpen them myself. Someday it will crap out and when i replace it I may "up grade" to a spiral cutter is they get good marks here.
Bart Goldberg
Bart Goldberg
>They list the cutterhead for the Dewalt 734 and 735 planers. You would need to call Byrd or Holbren directly to see if it will fit the 733.
Bart
Bart Goldberg
Bart Goldberg
>I use alot of highly figured wood in my projects. The fact that the spiral cutterhead nearly eliminates tear out is, to me, more than worth its cost.
Regards
Bart
