Butcher block construction
chuck_w
>what is the best glue for a butcher block table? I am assuming it need to be waterproof as well as food safe. thanks
chuck_w
Titebond III
doug f, san clemente, ca
>Chuck - I've made a number of cutting boards and a couple of butcher blocks for kitchen islands, all with Titebond III. They're still together and going strong.
Toxicity is no problem once it's dried.
Have fun with your project.
doug
Re: Butcher block construction
Rob Stokes in N. Vancouver
>Agree with the Titebond, though Titebond II would work fine as well.
Stay away from Gorilla glue though - it's the only glue that's ever really failed (for me), and it did so on butcher block style cutting boards (yes - more than one)
Re: Titebond III
Dave Paine
>I agree with the Titebond III. I have switched to this over Titebond II.
Longer working time, thicker so does not run out of the pieces as quick while I get the various clamps.
I have used this for maybe a dozen cutting boards in 2009, of which one was end grain design.
It is water resistant. It is NOT waterproof. Waterproof in my view means the item could be submerged and never degrade.
If you want waterproof to withstand long periods of submerging in water, this is certain epoxies.
I wash my boards under running water, allow to drain and no problems with Titebond II or III. I do not recommend allowing water to sit on a board for any period. The glue may not fail, but the wood may absorb sufficient moisture to expand and cause splitting.
I do recommend to the folks who get my boards that they NEVER put in the dishwasher. The combination of water, heat and time in a dishwasher cycle could destroy even the most stable lumber.
Re: Titebond III
Barry Turner
>You would think that people would have sense enough not to run a butcher block through a dishwasher. But, I learned a long time ago, not to assume anything.
Another option for you...
>If you can make your joints tight enough, Weldwood Plastic Resin Glue might interest you. It doesn't creep the way PVA glue does, which is why I prefer it for anything laminated. But the joints really need to be tight, as it doesn't bridge gaps the way PVA does, and it's brown in color, so any substantial glue line will show. Far as I know, it's watertight. As for Titebond III, I thought that got a Type I rating. If so, it's certified for submersion in boiling water. Gotta look into that.
I have made dozens with regular Titebond
Bill Tindall
>My first is was made in 1965 and still doing well.
People successfully made cutting boards before the marketing of Titebond II. I never tried putting one assembled with regular Titebond in the diswasher, but then that seems like a bad idea from a number of perspectives. Properly cared for a cutting board is never going to be soaked in water.
The exposure of the glue line to food is not something I get concerned about, but in any case anything that is an adhesive for wood is not going to be soluble and enter food.
