What is a screwdriver
Gary Smyth
>that has spring clips on either side of the blade called? The spring clips fit under Sears purchase, but they don't show at the store. Do these come in phillips versions too?
Re: What is a screwdriver
Ken Oakley Sunny- Sunny St. Cloud, Fla
>I was going to say Vodka and Orange Juice till I read your post.
Hiccup..swhatithought...hiccup
Terry Alexander
Dan Donaldson
>Probably a screw holding driver for starting screws. I have a philips version but it works a bit differently. Has two "V"s that meet at the points and spread apart when a slider is moved down the shaft and holds the philips so you can start it in awkward places.
A device for transfering torque, no more, no less
Ken Garlock, Collin County Texas
Yes, I've most often seen them described
>as screw holding screwdrivers.
>I call them screw starters. I have one flat blade and one phillips in my tool box. If you need one, you need it really bad. I also have a device to make a screw driver magnetic or to remove the magnetism. This is also very handy. I bought that when I was doing camera repair.
>I own some screwdrivers. Not really sure what they are for. I use them for opening cans of finish and for prying things apart. Sometimes I use the butt ends of the handles to re-seal cans of finish.
Screw-Holding Screwdriver
Charles
>Gary,
"Screw-Holding Screwdriver" is what I am finding on most sites.
Nick Tuzzolino
>I had a few of these. Bought about 35 years ago from Sears. I doubt if they make them anymore. Sorry, I don't know the actual name.
What is a screwdriver?
UnScrewed
Ray Newman
>Screwdrivers back out screws. Hammers put the screws into the wood (or metal)....
lol ;-)
Dan Donaldson
two names
Tom Dunlap
>My Dad had one like you describe...he called it a screw grabber
There is a split-blade version from Sear too.
I have one for Phillips that some one described already
Screw starter is another name that Dad used to use
Breakfast?
Rick L
Re: The correct answer is here...
Rick L
>Spring grip screw starter
Mcmaster page 2791
There's the spring type, split type and twist tip
