We value your privacy.
>Years ago, a woodturner shared a green wood technique w/ me and i wanted to confirm it w/ anyone else w/ experience. The technique had to do w/ turning a rough shape wet, placing it in a garbage bag for 30 days , turning the bag inside out daily, and at the end of 30 days the bowl had given up the moisture that causes endchecking.
I am being offered some wet wood in desirable thicknesses (4")for bowl turning. If they ship it to me w/ the ends waxed/ sealed in a garbage bag, will that minimize end and face checking? I realize that this may hinge on current moisture content. They sent a batch to me that was raw, ends untreated and the results were a disaster!
>Post this on the Turning Forum. (Look under Message Boards up on the left.) for more response.
But you have the right Idea. There is wide variation in the response of differing species and cut of wood. Some wood hardly cracks at all and others tend to be a bunch of cracks separated by tiny pieces of wood. Straight grained wood acts differently that wood with wild grain. Crotch wood is different than quarter sawn wood and so on.
You have the right idea. Rough out a bowl with about 10% thickness. That is leave the blank about an inch thick for a ten inch bowl. A twelve inch bowl might be an inch and a quarter thick. Whatever the thickness you choose, keep it consistent.
Then the fun starts. There are about a dozen ways to dry the blank. Put it in a paper bag and leave it. Put it in a bag with some of the shavings that came off it and leave it. Soak it in Denatured Alcohol (DNA) cover the outside with brown paper and leave it. Soak it in dish detergent, Dry it in a home made kiln, and then there is the ever reliable Voodoo. The time varies from species to species and climate to climate. Usually the time is a few months to a year. One way to tell is to weigh the blank on the first day and then occasionally after that. When it stops losing weight, its pretty much dry. You need an accurate small scale for this. You can also use a moisture meter or the kiss test.
Most people put the date on the blanks when they make them. After a while, you forget. Some people coat them in wax or Anchorseal, especially the end grain.
With some care and luck 90% of your turned blanks will survive. If the blanks are left in the solid block form the vast majority will fail.
There's another possibility that hasn't been covered here yet, and that is to turn your bowl from green to dry in one swell foop. That's what I usually do. Then, when the piece dries, it distorts according to the natural tendencies and properties of the species and the individual blank. Usually when you do it this way, you get very little endgrain cracking, as the bulk of the interior wood has been removed by turning.
If you want a more-or-less perfectly round piece, you'll want to rough turn it with oversize walls, put it in a brown paper bag for a while, and then turn to finish dimension.
Either way, the green wood blank should be sealed as soon as it is cut from the log with wax or Anchorseal, particularly the ends.
I have turned a lot of bowls green to finish. They warp, sometimes in strange and wondrous ways. Sometimes the surface ripples. You either like it or you don't. Gave one to a friend and he spent a lot of time trying to straighten out and make it dry right.
>I've dried sections cut off of a limb by using the bag inside out method. It does work but you have to be pretty dilagent about it or you get mold. I do mean every day for at least the first month. I layed them on a shelf at the entry of the shop so that was the first thing I did when entering.
As has been said you will get lots of mold on a full size piece using a plastic bag. Even a paper sack will cause mold although it usually takes a little longer.
for bowl blanks that I want to keep for a good while I wax them completely with parrafin wax melted in a used electric skillet.
for bowl blanks that I want to keep for a week or so I cover them with the paper sack.
Anything else I rough turn the bowl to 10% thickness and then let it dry for 3p3 to 6 months, or as Ellis said I turn it to final thickness of 1/2" or less just let it dry out if direct sun and wind for a few days.
>Take a look at the Alcohol Soaking Blog for a good way to dry roughed out bowls. Feel free to email me if you have any questions. But questions asked and answered on the forum benefit more people.
