We value your privacy.
>I recently purchased a thermal leak detector in an effort to insulate my house a little better, and have made some interesting discoveries. Other than the usual suspects needing more insulation (gaps around doors, window sashes, and electrical boxes on exterior walls), I've discovered several of my windows have significant air leaks under the trim moulding. For example, there was 31 degree air coming in between the moulding under the window sill and the interior wall in my bedroom last night. I'm assuming the only way to tackle this would be to take off that piece of trim, insulate behind it (spray foam?) and reapply the trim. I'm pretty sure that's going to have to involve at least some touch up painting though, and I'm concerned that could grow into a huge project (particularly if I mess up the drywall trying to pry off the trim.) Just wanted to see if anyone had any other thoughts. Thought about trying to drill a hole through the moulding, spraying in the foam, and puttying/painting the hole. Only concern about this is I wouldn't be able to see where the foam goes, so may not seal up what I'm trying to do.
>Don't know anything about your windows or how your house was constructed, but I would recommend you try the low pressure Great Stuff foam (blue can) if you decide to shoot it in under your trim. I have a friend that did significant damage with the regular stuff (red Can). It expands at enough pressure to jack up the jambs and sills of windows. I think it would take a hole about every six inches to fill under a sill.
I'm not sure what makes this gadget any different that a regular infrared thermometer, but it looks interesting.
One thing to check for is air flow around the trim. There was a weatherization program years ago in VA and they found it was more effective to caulk the inside trim to the drywall than to try to caulk the exterior of windows. You might try thoroughly caulking your trim and see if that does the job. I agree that removing the trim and reinstalling it might be more trouble than it's worth.
>What makes the B&D unit different from just a plain IR thermometer is that it shines a light where you're measuring, and the light changes colors according to the temperature difference. To explain further, you point the unit at a "reference surface" and turn it on. This gives you a green light on the wall, and a reference temperature. You then scan over whatever area you're checking, and if it gets colder, the light turns blue. If hotter, it turns red. You can set the temp scale to change colors at 1, 5, or 10 degrees. It also shows you a reading on the LCD screen, but watching the color change is much easier. For example, the area I was checking was upside down near the floor. I would have had to stand on my head to be able to read the screen, but as it was, could just look for the color change. Pretty neat idea. No affiliation w/ B&D (honestly, don't like most of there stuff!), but this one works pretty well IMHO.
>If your concern is air flow, why not just caulk the joint?
Your window probably sits on a rough sill, with an uninsulated gap. Insulating that would improve your insulation, but may or may not be worth the effort.
Your window may have fiberglass wool packed around it. Works well, but not with air leaks. Caulk the air flow first.
Also - - If you are feeling cold air leaking in from around your windows, your house is operating in a slight vacuum, sucking air in from any available source. Dryers, furnaces, bathroom vents, stove hoods, fireplace & wood stoves all contribute to this vacuum. If you 100% seal off your house, these appliances won't work, as they need make-up air from some place.
In my furnace room, I put an air vent and some ducting to allow outside air into the room. Many codes require this, and have design criteria for how to install them. Doesn't make that room necessarily cold, but does give a designed "leak" to the house, reducing air infiltration in the rest of the house.
>Lots of my Buds in the Home Inspection business use IR thermometers, mostly to take the air temp coming from a heating system. It does not seem to occur to them that the thermometer is not reading the air temp, but the temp of the surface. Works OK if you let the system run long enough to raise the temp of the grills. Not so good if you are in a hurry.
You would enjoy a thermal imager for what you are doing. Like a digital camera but it reads the temp at thousands of tiny spots and forms an image. Can be astonishing. It seems to be able to "see" right through something like an electric motor. The imagers have come way down in price but are still thousands of dollars.
>Yeah, would love to have a thermal imaging camera to play with, but certainly couldn't justify the cost. Buddy of mine is a volunteer fireman, and they have one they use to find "hot spots" behind walls, in ceilings, etc. He says they're quite amazing as well.
How easy this is depends somewhat on how the apron was attached. In our old house, I've found nails driven all kinds of ways into the window trim.
Advice:
Get a molding pry bar. I really like hive tools (which used also to be sold by Red Devil as painter's and carpenter's tools; but they're no longer listed on the Red Devil website) - example in the link below, but you can get them from any beekeeping store, and you may well have one in your neighborhood (note: I have no affiliation with the website in question, nor any knowledge of it; I got my hive tool at a garage sale). There are other styles of molding pry bars as well, which have in common a really thin edge, but hive tools are very affordable. It's good to have one of these (two, if you're feeling flush) and a stiff 1" putty knife, so you can "walk" the apron or other piece of trim out from the wall.
Strong diagonal-cutting pliers are handy, too - sometimes a reluctant nail is more easily cut off once you can get the pliers in behind the trim.
Also helpful is a nailset and/or thin pin punch - if you encounter a finish nail driven into the apron from the sill, or from some other odd angle that will split the apron, and if you can figure out where its head is, you can sometimes drive it through to free up the apron (the same applies in removing other trim, of course).
The final needed tool is patience - if at first you can't figure out why it's not coming off, take a breath and fuss more slowly. 90% of the time, you can get trim off without breaking it. Glue and spackle were made for, among other purposes, taking care of the remaining 10%.
>Reading the other posts brought something to mind.
In a even a fairly well insulated house the principle source for heat loss may very well be air leaks or infiltration. If you are trying to seal around your windows, that is what you are working on.
Your leak detector does not actually "see" the leaking air. It sees the cold spot created by the cold air moving past the surfaces, scrubbing away the heat. All of the foamy or fluffy types of insulation depend on keep a layer of air still. It the air (Or gas) that is the insulator. Fiberglass for example, the glass is not an insulator at all, it the air among the fibers that does the job and the air clings to the fibers, holding it still. Foam is often better because the air or gas is trapped in tiny bubbles and can not move. The fibers can not hold the air still if it is being pushed by the wind. Foam may also seal the gaps and stop the wind.
In order for air to leak through a crack it has to have an entrance and an exit. (Goes into and Goes Out, as a friend used to say). There must be a way in and a way out. IF you seal the cracks on the inside, it will have trouble moving into the space around the windows because it can get out. If there is not flow through, there is no flow. The space around your windows will be fairly good insulators on there own if there is no air flow, even if they are not insulated at all. A little fiberglass would be better than none, if there is no air flow.
In a larger sense, if air is leaking into your windows it is leaking out of your house somewhere else.
If the wind is not blowing the force that carries air into and out of your house is the Stack Effect. The same thing that makes natural draft chimneys work. Warm air rises against you ceiling and escapes into the attic. Colder air is pulled into the house down low, through the floor. Unless you live in a windy area, the stack effect is more damaging than the wind. it takes about a 6 or 7 MPH wind to make even poorly installed widows leak. Locally we have that much wind less than 15% of the time. The stack effect is relentless 100% of the time that it colder out side than inside.
So, there is positive pressure against your ceiling and negative pressure again your floor. Seal light fixtures through the ceiling. Stuff the holes the plumbers left through the floors Caulk around wires and pipes. Its a lot of work in an older house but costs nest to nothing in materials.
One last thought, you can also have induced leakage. Turn on all the exhaust fans in your house and the air has to come in from somewhere. 2 or 3 bath fans, the hood of the range, and the dryer...and you may find air coming back down the flue or out of the water heater if it is gas. As someone else mentioned the building code used to count on leakage to make up for this air. Then they started to require make up air vents. If you were really zealous and sealed you house to the max, you could set up a dangerous situation. A building scientist I know calls Jenn Air ranges Yuppy Killers. You seal your house in Evey way you can think of, including new super windows. You remodel the kitchen and install the new super range and hood. Have your friends over and have a nice old fashioned fire in the fireplace. As the fire dies down, the draft fails and the fumes come back into the house.
I was trying to figure out how you could use your leak detector to find ceiling leaks. With nothing burning, turn on all the exhaust fans and see what you find both high and low.
