Long: Grizzly Spiral-head cutter installation-----
Dave Bair, Eaton Rapids, MI------WebKitFormBoundar
>I decided to upgrade my JET 6" jointer with a Grizzly spiral-head cutter. They offer three "brands" that fit my jointer; I chose the Grizzly brand because it comes with bearings, bearing blocks, mounting studs and pulley included. And it was the cheapest of the three offered. Even at that, it cost nearly half as much as the original cost of my JET.
I must say, the installation went easier than I could have hoped for. Their cutter fits a number of brands, so it's pretty generic. But their instructions were clear and the drawings were accurate enough to work with easily.
My only problem came with the long bolts that hold the cutter to the jointer. I was able to get an open-end wrench onto the JET's bolts and remove the stock cutter. But the stand kept the studs from dropping out of the bed. In order to use the studs that came with the cutter, I'd have to remove the jointer bed from it's stand. That's not something I really wanted to do since, even though it's a small jointer we're talking several hundred pounds here.
On a whim, I tried the Grizzly studs on the JET cutter head assembly. They were a perfect fit which meant the stock bolts would fit the Grizzly cutter. It went in on the first try and I was able to torque it down good and tight, even with the open-end wrench.
The instructions showed how to measure for any needed shimming of the assembly. I used a dial indicator instead of the straight-edge-and-shims method they outlined. They recommended shimming to within .004" of parallel. Mine was within .001" without shims. A nice fit from both Grizzly and JET.
The cutter is perfectly balanced, although it apparently took a good deal of effort, given the number of drill holes, to get it there. It just hums along very nicely. Fine tuning the outfeed table showed how different these cutters are from the standard straight-blade stock version.
I've always had to set the outfeed .004" below the TDC of the cutter to get a well-jointed edge. With the spiral head and it's 34 cutters in 4 rows, that setting got me a lot of snipe. Setting the table dead level with TDC yielded a perfect joint. The finish is very smooth, without the scalloping I got with the old head unless I ran the piece along at a crawl.
I am very pleased with the new cutter head, even though I turned what should have been a one-hour installation job into twice that. I especially like the idea of never having to level those three knives every time I needed to replace them. That always ended up taking at least two hours and lots of compromising. Now all I have to do is rotate those carbide chips and I'm ready to go.
------WebKitFormBoundaryAtbMUDVpq+qNX8YB
Re: Long: Grizzly Spiral-head cutter installation-----
Paul Woolson
>I made the same upgrade. Best money I've spent in my shop. I bought the one made in KY that didn't have bearings or Pulleys. It wasn't a big deal to bull them and re seat them but I too took way longer than I should have.
Try this for a test cut:
I took a piece of fiddle back maple. 1x3x36. Ran one face through the jointer (yeah, try that with three knives) and one through the wide belt sander with a 220 belt. The jointed face actually looks better. I keep the board hanging in my shop because most folks don't believe me when I tell them that.
>I believe you; mine compares well to the finish I get with a hand plane. I'd also note that the spirals also push the wood into the fence, making edge-jointing a somewhat safer operation.
