We value your privacy.
OT: spray in foam for the house attic What is it??
del schisler
>they make a foam spray for the attic and bacement That a machine is used It uses a long hose The stuff must have a chemical that is added to make it foam as it is sprayed into the attic or bacement?? Does any one know of this ?? The foam is like the tube's that you can by at the home centers A friend is looking for info thanks for reading del
Re: OT: spray in foam for the house attic What is it??
>I think you are talking about Icynene. They promote it on This Old House, Etc.
You could be talking about Urethane. That is what is in those cans (I think). Urethane is available in bulk quantities and is sprayed in from a truck. Both Icynene and Urethane are sprayed in from a truck mounted system and I believe what happens is the mix the chemicals right at the nozzle and they expand when they hit the surface.
Not sure what Icynene is made of, but there are some soy based foams out there. Important that the foam does not readily burn or attract insects or rodents.
Google is your friend, I'm about to go read up on this stuff.
>Have to wonder. You pump this stuff into every nook and cranny, walls attic, etc., sealing your residence tight as the usual drum-head against those nasty drafts.
How long before the toxic mold in the walls grows to the point where the house has to be torn down?
I thought we learned the lesson of the "super-insulated" home when you cut off air circulation and trap internal water vapor, but maybe not.
What may be just fine in an industrial context doesn't necessarily translate to residential applications.
Just wondering, of course. Don't know enough about the stuff to form an informed opinion, but do know enough to pose the question.
>As long as it is done properly, there is nothing wrong with a super-insulated home. Just the opposite, in fact. But the key is to _have_ the proper ventilation rather than depending on the entire house leaking like a sieve -- you use a heat/humidity recovering ventilation system (depending on your climate). I'll tell you, I'd really love to have a modern super-insulated house with stagger-studded walls and all the other bells and whistles then I wouldn't be paying so much money to the gas and electric utilities every month. Better in my mind to spend the money up front rather than paying for it every month for the rest of my life.
But back on the original topic. There are do-it-yourself foam insulation system (Google steers you to several using that search string) but in my mind this is something you probably want a professional with a truck-mounted system to do for you. Besides, the do-it-yourself version looks to be twice as much as the pro version based on quotes I've looked at.
>I tend to agree. Just spent a while reading about this stuff on the Internet. Internet=the source of all the half baked information in the universe.
The potential problems with Icynene and any other spray foam are so varied and far reaching as to be scary. From what I just read there are huge potential problems with the chemicals and the equipment. Bad batches, batches that were stored too long or too hot or too cold. Guns that are not mixing the chemicals correctly. Then it turns out that the cavities have to be at the right temperature and dry and clean. Just as we discussed the other day about your using gas in a shop heater, how do you heat a cold unfinished/uninsulated house? With gas or kerosene heaters.....that warm the air and blow out substantial moisture. The moisture vapor condenses on those cold walls, the very surface we want to be warm and dry. Then the foam not only does not stick well, Icynene is a water based foam and if the surface is wet, the very chemical reaction is compromised. So, there are a bunch of variables that I am not sure the guys that do construction understand or care enough to deal with. Their job is to get in, do the work, and get out. Not sure they are going to be fussy enough about the conditions. Might seem a little prissy for them.
Beyond all that, I wonder about the other aspects of covering everything with foam. How am I supposed to find the roof leak if the foam covers the sheathing and rafters? Or who catches the termites snuggling under the foam on the way to and from your framing? Maybe the foam won't support mold, but if the wood behind it is wet, the wood will. Could be perfect conditions for rot.
Its a case of if you change one thing you change everything. Not saying its bad, just very different. A case of you have to take a system approach to this and the whole house is the system.
>What is really needed when a house is sealed up tight is an energy-recovering ventilator. They are rarely used, probably due to cost, but I think they're necessary for a healthy, energy-efficient home. Basically, there is a fresh-air intake that runs through a heat exchanger containing the exhaust air. I believe they can be a part of a forced-air HVAC system, or a standalone.
On top of that, one of the biggest problems when it comes to tight homes and mold is that the attention is on air-tightness, but often details pertaining to water infiltration (poor construction and flashing details) are overlooked. For instance, I often see wood or fiber-cement siding installed directly over foam board--with no drainage plane behind it. Capillary action keeps the siding wet on the back side, promoting mold/mildew growth.
Jason
>I can see that this stuff would be great sprayed on the interior of steel buildings including the metal roof decking. Spray it on the bottom side of OSB or ply roof sheathing, and I'll bet the rot starts in a few months.
