refacing cabinets myself
scotty3179
>I would like to reface the cabinets in my kitchen. The boxes are fine and I would like to make the doors and drawers. I will be making the raised panel doors and dovetailing the drawers. I was wondering if there is a website that I could visit to learn alot more about this project.
I have lotsa questions about this. I know what hinges I want to use, but do I stain all the skins when everything is installed and then laquer it. That is not gonna make my wife too happy with the stink. A local cabinet shop refaces cabinets and lines the entire faceframe with 3/16 thick wood. Does that need glued and pin nailed up or what? What do most people do when refacing cabinets? Stain when all is up or do all before. A website would really help me or some good advice.
Re: refacing cabinets myself
Dick Coers
>I refaced one kitchen, and did a combination rebuild refinish on another. The one refaced, I used adhesive backed veneer to cover the ends and face frame. I stained and finished the adhesive backed veneer before applying. Unless you are striping the old finish off the current cabinets, you will be limited to contact adhesive, or some sort of acrylic adhesive like is used to glue up tile. No other glue will stick to the finish of the old cabinets. I would be concerned about using thicker material, especially plywood, because it is so difficult to keep flat. Make sure to really clean before trying to put on anything. Kitchen grease is tough to remove. I suggest TSP. On the second job, I was covering steel cabinets. The had a flange on the front, so I built face frames and screwed them from the back. I used 1/4" plywood on the end caps, but used good two face so I would have the best chance of it staying flat. I used contact cement to hold them on. It's been on for 15 years. The first one I have no idea if it still around. Sorry, can't suggest a web site.
Richard McComas
>Many moons ago when I was in construction I did a couple cabinet refacing jobs. I did one for one of the owners of the company I worked for. They turned out very well and was easy although time consuming first time out.
I used the product from Keystone Wood Specialties (link at bottom of this post). At that time they had a very good video of the process. They still have the video available though I sure it and upgraded version from the one I had.
The basic process go something like this: I ordered the doors, drawer fronts,pre-finished PSA veneer, and a couple recommend tools for the job. one key tool is a fiber scraper used to press the PSA veneer to the existing cabinets. Never use a J-roller to apply PSA use the scraper. The second link at the bottom of the post will take you to their page where you will find the tools and video.
The PSA veneer sticks very well and permanent to cabinets with a finish on them provided they are clean. The video covers the cleaning as well. There is in my opinion no reason to get involved with thick materials and contact cement, the PSA work very well.
Now that I got you all excited the one problem you may face it that Keystone Wood Specialties is a whole sale only company according to their web sit. However some companies will sell to you anyway if you just make up a company name.
If I was you I'd start by ordering the video and use a made up company name and see how it goes. All they can do is say no. In this economy I'm betting they will sell to you.
Hope this helps.
http://www.keystonewood.com/
http://www.keystonewood.com/refacing-tools.shtml
>Just saw a set of cabinets that had been refaced. At a glance they were attractive. They were white with some black accents, not to my taste, but still attractive. Looking closer revealed they had been covered with what appeared to be very thin (vertical grade) plastic laminate and it was coming loose. There were a number of puckers in it.
Not sure, but I think this is an indication the installers did not clean as well as they should have. So, I can't help you much, but whatever you do, clean and then clean again.
Re: refacing cabinets myself/option *LINK*
Bill Sams
>If NOT refacing is an option, you might consider it.
Last spring I re-worked a kitchen by replacing all the doors and drawers but leaving the old face frames as a contrasting wood, with only light sanding and refinishing the old frames with "sealcoat', then water based poly
The old kitchen had plywood doors and stained a dark walnut. I replaced with sassafras doors in an Arts and Crafts style which were finished natural.
Below is a link. Again I only present this as an option.
http://jwsjoinery.com/jws/sassafraskitchen.html
Fred Davis
>Just a thought...
Since your already contemplating doing two out of the three most difficult stages of a set of Kitchen cabinets , namely doors and drawers, if you did a complete set in your shop , then the third step, applying finish is made easy.
If not , think about painting the old boxes and lacquer the doors and drawer fronts in your shop , not in the Kitchen.
Just like any other option , go over the old work with TSP.
FreDD
Face Frames
>I helped a friend do this and we used 3/16" stock like a heavy veneer. Made and prefinished the stuff in the shop leaving a bare-wood strip down the back for the glue line. It was then cut to fit in the kitchen and glued on the pieces using 2" wide blue tape to hold it until the glue dried. Face frames have been solid for 10 years so I guess it worked ok.
btw, not to dissuade you from making new drawers, but simply doing new fronts and pulls works if the drawers are in good shape. If you do make new drawers, consider Blum-motion tracks. Self closing and velvety smooth is very sexy. She'll love them. Same thing for the door hinges.
mm
Pete in Holland, MI
>1) Used 1/8" thick door skin plywood for the face frames. Clean & coarse sand the face frames. Yellow glue & air brads. Held up for 12 years now. Edges of the plywood are not really noticeable unless you look for them. Would do it again in a heart beat.
2) Take the time to replicate the plank layout on the face frames, else, to a wood worker, it looks "not right".
3) Used spring loaded hinges that allowed the doors to overlay 1/2" per side.
4) Before starting to add wood, find a paint similar to the color of the finished wood & paint the interiors of the cabinets. Spruces them up. A good semi-gloss latex is adequate. Light back panels allow for more natural light to come in & see what is at the back of the shelf.
5) Used the same drawers, as they were plywood & in good shape. All were given a coat of paint and have held up well. Make sure to use oil base paint here, again, similar color to the finish of the real wood outside.
6) Drawer faces & raised panel doors were all new. About $150 in router cutters and a solid router table got me thru the process.
7) Even went to the extent of harvesting the trees & had them milled into lumber (red oak). Entire cabinet upgrade cost me less than $700 12 years ago. Included lumber, finishes, hardware.
Pete
Richard McComas
>Something I didn't mention in my first post. When doing the face frames you slice you veneer wider that the frame and the use a sharp knife chisel or razor blade and trim it off. where the stile and rail meet the veneer is over lapping and you make a double cut and get a perfect seam ever time. The no saw dust or router chips flying all over the palace.
Jerry Samsen
>I had my kitchen refaced 10 years ago before I got into woodworking. The "kids" that installed it used the PSA backed veneer for the face frames but no contact cement. We hired another guy to do the finishing using tinted lacquer. Within a day, the veneer started to bubble and peel up. The owner of the company came out and said that the installers screwed up and the face frame should have had contact cement first to secure the bond with the veneer. They paid to replace the veneer and redo the finishing job.
Later when I got my shop in order, the first thing I did was reface two bathroom vanities -- one large and one smaller. I built my own doors and drawers and used cherry PSA veneer I purchased from Rockler. I used 1/4" cheery veneer ply on the sides of the cases and and applied contact cement to the face frames before applying the veneer. Never had a problem.
I stained the veneer and ply before installation but then finished (wipe on varnish) after installation.
After I did this I kicked myself for paying so much to have my kitchen done after I realized how easy it was. And my work was much better quality than what I got in my kitchen.
I would highly recommend buying the book "Refacing Kitchen Cabinets". You can get from Amazon or Rockler. Takes you through the process. Rockler also has a simple cutting guide for trimming the rails to the stiles.
