OT Radiant Floor Heating??
Thomas Norton
>Anyone out there heating via this method? I would like to "talk".
Thanks
Re: OT Radiant Floor Heating??
Lee Grindinger
Yup
Lee Grindinger
>I built it into our home in Montana. Flexible tubing, Wirsbo, calculated loop lengths, embedded in 1 1/2" mortar, with tile over that. It was the best heat system I ever lived with.
However! It's slow to respond, do not expect warmth quickly, it's a system to set and forget and operates most efficiently when the thermostat is left alone, do not plan on nightly set-backs. There is no "hotspot" in a room to warm when chilled like when you come in from the out of doors, like what you have with radiators or forced air.
I would never use it in a workshop because the warm floor is too warm for working on.
Ask away, I installed the system myself using a pro for advice and schematics and materials acquisition, he'd done the systems for over a decade.
Lee
jesse cloud
>Me too. Didn't install it myself, but ditto to everything else Lee mentioned. Nice to hop out of bed in the a.m. and have warm tile underfoot. Totally quiet, no drafts. But it takes 4 or 5 hours to stabilize to a new temp setting. A little chilly here in the a.m. We have 18 degrees at night and forties during the day, so I wear a sweater or long sleeve shirt first hour of the day. Very low maintenance (just clean dust off the boiler couple of times a year).
Wouldn't trade it for anything.
>As a Home Inspector I have seen a bunch of these and would echo everything said above. A properly installed well adjusted system is very pleasant to live with. Almost everybody that has a good one loves it. But the disadvantages are as mentioned. Very sluggish to respond to changes in the thermostat. Can be slow to catch up if the weather changes (slow to change or sort of ponderous). If a cold snap rolls through you might take half a day to catch up. If a warm sell hits you might be uncomfortable for a few hours. In a well insulated house these effects would be minimal. The systems can be expensive and do not provide for air conditioning. In our relatively mild climate in VA heat pumps dominate the market because they do not require gas or oil fuel supplies, don't require a flue and provide both heat and AC. OTOH, heat pumps blow out relatively cool air and nobody really likes them. Another small benefit to air systems is they filter the air and can provide an opportunity to humidify. With a heated floor, the house can be cooler and still be comfortable and you may not need humidification.
I just read an article about using solar water heaters to provide the hot water for a radiant floor system. Interesting. Expensive, but interesting.
mdclor
>Tom,
I mostly agree with the others, but I have it in my shop and had it in my previous shop. I have the shop on a separate thermostat and keep it set at 60* which is fine for working. By all means, set the thermostats where you want them and don't adjusting up and down twice daily. If you do go with radiant heat, be sure to put insulation and a moisture barrier under your concrete if you have it in a slab. One really nice feature is that the slab will continue to radiate heat even if your power goes out for a period of time due to the thermal mass. Feel free to email me directly with any additional questons.
HTH,
Merle
Dan Donaldson
>One other thing that can be nice is that the pumps that circulate the water are not really very big. Depending on the heat source (like something NG fired), it is totally practical to run the pumps on very small generators or even an inverter.
Solar water heaters?
Joanne in Pt. Pleasant, PA
>Hey, Barry--can you tell me where you read that article? I'd be interested in reading that, too. I have radiant heat in my shop, which is a big barn. It is powered by a propane-powered hot water heater. I'd love to convert that to solar power, if I could afford it. I figure it should pay for itself pretty quickly, depending on the price of propane. Then I could afford to set the thermostat higher than 53 or 54.
Re: Solar water heaters?
Fred Davis
>Now is a excellant tax break time to install solar collectors.
The Government is making it really easy to go that way.
For in the Slab radiant heat , we have it in this home which was that way when we bought it.
Uses a Cast Steel wood fired , fire box with a water jacket inside and pump on the back.
Cost's us less then two hundred this year for Hedge, split and delivered for fuel.
This home also has a High effiency natural gas Bryant furnace we replaced the old one with and a large fireplace with a metal inset and fan in the living room.
Neither is used in the wintertime though I heard the furnace kick on last night when it got down to ten below.
The only gripe I have about the radiant heat is the King size bed traps a lot of heat in the day and I like it cool in the bedroom for sleeping , but then this is a small thing compared to some of the heat bills I hear people paying for Propane to keep warm.
My wife loves it becasue she can go barefoot comfortably. ;-))
FredD
Terry Quiram
>Thomas
I heat a 1400 sqft workshop with radiant. I keep mine set on 62. I love it. If you are insulating for radiant you might as well add AC.
>Joanne, somewhere along the way I signed up for HGTV Pro news letters that come by E-mail. Their email address is contractornews@hgtvpronewsletters.com. The article was about a house that operated at zero use of outside energy and they claimed the house only cost 7% more than a conventional house. If that link does not take you there try Googling HGTV and hunt around.
This would be a good application for solar. With a lot of panels its easier to genertate a lot of warm water rather than a lot of really hot water. Warm being 80 to 110 degrees. With a large tank of water over 80 degrees, you could keep a slab toasty. If the tank were inside your shop and fairly well insulated, any heat that escaped would be inside the shop.
alister
>There are several plans for collectors and other interesting things at
http://www.builditsolar.com/
jerryburns
>I put a warm board system in my addition and I live in Northern Ill right now outside air temp is <20 and my kitchen is 70 a pump and a hot water heater is what I set up r 30 in the crall and attic and r 19 in walls works great I did not start my main heater until Dec 1st this year. and I installed it myself.the warm board is the subfloor it i 1" thick and has channels cut into it for the tubing Warm board did the layout for me I just put it all in
any question email me
